Question about Vacuums
My Windsor Versamatic plus has all of the sudden become very hard to push. I maintain this vaccum very well. It picks up fine, just to heavy tp push apparently
    Brigadier General:
  • 4,088 Answers
Likely the wheels are frozen with thread and hair at the sides of the wheels. Check for free movement of each wheel and pick out the debris around any that are hard to turn. Long needles and tweezers are good tools for this.
Posted on Jul 26, 2009
Required Industrial vacuum cleaner heavy duty
For an upright industrial, I would suggest a Windsor or Tennant brand. New ones are cheaper on the Windsor site- both the windsor upright and Tennant upright are made by Windsor (Just like Ford and Lincoln cars are really the same thing- even the part numbers match) Tennant sometimes sells used vacuums. The windsor is the hardest working upright I've seen, and is the easiest to work on/change brushes on. I retired from fixing cleaning equipment after 30 years. Just be sure to get the Tennant with the side hose- it'll last forever.
Apr 05, 2017 | Vacuums
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
The handle release on windsor s12 won't spring into place
You likely have one of two problems. Your return spring is broken, or your axle is bent. If your axle is bent, carefully inspect your chassis to be sure that the bent axle has not cracked or otherwise damaged the chassis. I have included a parts list as well as some links to these parts for your reference. http://windsorvacuums.com/partslists/s12_PARTS.pdf 2010 Axle Spring 86146570 windsor allstar javelin 5053 Windsor Sensor Axle 86137990 allstar javelin
Jun 17, 2014 | Windsor VS14 Versamatic Bagged Upright...
My windsor sensor 12 inch vacuum is to hard to push. I bought a new one and its doing the same thing. My vacuum repair man says he cant fix the problem. My shoulders are sore from working so hard. Help
It\'s possibly the type of carpet you\'re using it on. The sensors use the brush speed and the amount of air flow to determine carpet height. Some berber, and tweeds make these things horrible to push. We sell sebo, who make the windsor and we\'ve had the same issue on random carpeting. We end up selling the G- Series units in these situations because they adjust manually so not to suck themselves tight to the floor. Sebo/Windsor make amazing products but there\'s just no helping this, it happens sometimes.
Happy Vacuuming!
The Vac Dr.
The Vac Dr is always happy to help. If you\'re having trouble finding someone to help contact us here.
Jul 20, 2012 | Windsor SR12 Sensor Bagged Upright Vacuum
Broken motor pulley windsor vacuum
I have the same problem, maybe we can flip the belt over and let it run on the smooth side for a while. That's what the person before me did and it lasted a good 6 months.
Feb 24, 2012 | Windsor VS14 Versamatic Bagged Upright...
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
I have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Jun 03, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Central vaccum
If the outlets work on the 2nd story ok, and not on the 1st floor, then you may have a wire that has come loose. There maybe a junction that split off between the 1st and 2nd floor. I assume you are talking about the suction and not the brush roll on the power head. If it is the power head not working, then check where the 2 prongs go into the outlets to make sure that the plug receptacle haven't gotten pushed in from the holder.
May 30, 2007 | Windsor SR12 Sensor Bagged Upright Vacuum
Vacuums Logo
62 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
