Question about Compex NetPassage 26G / iWavePort WLU54G Kit (WSK217U)
Usr and pass
I cant get the Username and password to ever work for my Ip adress.. Please Help
Remember default password - password
Posted on Apr 07, 2008
    Problem Solver:
  • 6 Answers
TO reset the router. what you need is a paper clip. make it straight and look for the reset hole at the back or on the buttom of the router then push on it. The settings will then be reset to its manufacturer settings. For panel use the browser and type on address then it will prompt for username and password. Key in the default for your product.
Posted on Nov 22, 2007
  • 244 Answers
Reset the router to each default settings, there should a reset button in every router. Usually located at the back of the router or in every side. The default user: admin pswrd: admin or fill in blank(empty). the ip add should be
Rate me SOLVED
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through because its not admin i changed that to. can u help and tell me what to do. i have...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
Buffalo - Username: root Password: Leave the field blank Default IP address is:
D-Link - Username: admin Password: Leave the field blank Default IP address is:
Encore - Username: admin Password: admin Default IP address
Linksys - Username: admin Password: admin Default IP address
NetGear - Username: admin Password: password Default IP address will be: or
TP-Link - Username: admin Password: admin Default IP address
TrendNet - Username: admin Password: admin Default IP address
Zhone - Username: admin Password: admin Default IP address
Zyxel - Username: admin Password: 1234 Default IP address
Sep 07, 2011 | Linksys WRT54G2 Wireless Router
I change my old fios router for a new one my computer work but not my laptop. cant seems to find the password to reset
If you have manual of the router, read what's the default IP adress for accessing router. You can also try typing the instead of a web adress in your WORKING COMPUTER'S web browser (this is the default IP usually). You will get window with username and password (you will find username and password in the manual of the router). When you access router, you can turn Wireless LAN on/off and change all values you need. You really should read manual first, it will all be clear to you after that.
May 21, 2011 | HP Pavilion dv6000z Notebook
How do i find my wpa2 key for this router? i have tried typing in th ip adress on my adress bar and it wont let me access the page.
What IP address were you entering in your web browser? Were you prompted for a username and password, or was the browser simply timing out when attempting to make a connection? I believe the default IP address for the router is so make sure you're entering in your browser. If you're then prompted for a username and password then enter 'admin' for the username and try and leave the blank field blank then click 'OK' and see if you're able to login, unless you've changed this information.
Mar 01, 2011 | D-Link DGL-4500 Wireless Router
Router does not save the ISP user to connect to the internet
some of the router have fixed Username and you can only change the password.
Mar 31, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
Need to change netgear router rp614 from dsl to cable
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex or
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex or
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Feb 07, 2009 | NetGear WGR614 Wireless Router
Problems with my linksys
check if there is a little red button on the back .... that says reset click it,.....if not then go to intenet explorer ... type the ip in the adress bar..... a username / password sign should come on ... for username leave it blank for the password right admin and it should take u to a internet sight ..... go to security settings and reset it ...u will figure it out from there truse me ! hope i helped -el
ps. the ip adress is
Dec 25, 2008 | D-Link DI-704P Router
Can't connect to web configuration
There is a reset known as a 30/30/30 reset. Hold reset with power on for 30secs, unplug power while still holding reset for 30 secs, plug power in while holding reset for 30 seconds more and release, wait 30 secs or more for reboot. This should put it back to factory defaults regardless of brand. Set your IP manually on the PC to be Open your web browser and type in the IP address of the router ( by default). Enter the username (admin) and password (blank by default), and then click Ok or Log In
Aug 26, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Aug 03, 2007 | Emulex NETQue Print Server
Compex NetPassage 26G / iWavePort WLU54G Kit (WSK217U) Logo
143 people viewed this question
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
