Question about Kenwood Audio Players & Recorders
I have hooked up outside speakers and they are playing the song but the audio for the voice is weak or not at all playing. I think my receiver thinks they are surround speakers and not front speakers. everything is hooked up right and my old ones used to work. I think I have some button that is pushed and not working.
silly girl
  • 513 Answers
SOURCE: onkyo srtx601 receiver
Please add a comment to your previous post next time, it makes it easier to see this post has a relevant history. I had to go check in your profile when I saw the word "still". Shooting in the dark, and saying the obvious(just bear in mind a month ago I was going crazy over a problem that ended up being the blanace knob turned to the right) - could it be that you're not using a digital signal? I'm not sure you can get surround with analog. Make sure all settings are for digital, and that you're using a coaxial/optical cable going from the DVD to your receiver. I hope you'll end up embarassed but happy. Good luck
Posted on Jun 19, 2006
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
jusus
  • 57 Answers
SOURCE: AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very important.you may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Posted on Feb 28, 2008
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Hook up patio speakers and use my cd/dvd/cable/ipod outside only
i'm not sure if this will work, but you could try connecting the rca stereo cables from you cable box to the cd input on the receiver those would be analog. then you could use the music channels at least. as for an ipod maybe sort of the same thing using an av cable instead of the dock;like i said i don't know if it will work but just a thought.
luke
lukeshkin@hotmail.com
Posted on May 30, 2009
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
Jvc rx-9v won't send sound to speakers
check the speaker selecter switch, and do it with your radio on, because that does not need any outside connections, just an antenna
Mar 07, 2013 | Audio Players & Recorders
Voice volume is low compared to background music volume on AVR-2808CI
Could be a number of things.
Most likely your surround sound mode. Some people dont like Dolby. Try to switch to 5 channel stereo.
Other option is to turn the center channel speaker channel volume up. Voices and dialog come from the center channel speaker in Dolby modes. Post back if you need instructions.
Please rate my solution.
Nov 30, 2009 | Denon AVR-3805 Receiver
Add more speaker to dvd player/s-air suround sond system
I have revisted this question and I *think* you are talking about a "speaker selector". A speaker selector is a unit that prevents an amp or receiver from going into safe mode or shutting down.
Follow this link:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-224
Mar 31, 2009 | Yamaha RX-V463 Receiver
Have stopped getting voice audio.
Reinstall the Audio Device driver .
Mar 31, 2009 | Audio Players & Recorders
No voice audio
Have you selected coax mode with the input button?. If so you may need to play around with the setup buttons. Can't give anymore advice as I've lost my manual. Good luck
Dec 26, 2008 | Sony STR-DE585 Receiver
Denon AVr hookup advice
Hi khanfaisalv
You can use Zone2 feature that is built into this amp, then have dvd playing in one room, and cd playing in another. Both controlled separately
Page 10 of the manual tells you how to hook up the wires to Zone2
Page 30 has details of how to get it up and going.
Good luck with the rewire job, thanks for using FixYa
regards
robotek
Jul 06, 2008 | Denon Audio Players & Recorders
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
62 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
