Question about Philips Televison & Video
Phillips rear projection tv turns off after 5 seconds
I just got a phillips rear projection tv manufacture date May 2003 model 55PW9363/17, chassis DPTV33/5 for free. The other owner said the convergence chips went out, and he replaced them himself, then nothing worked., I have repaired the sloppy solder job, and now the tv turns on then off after five seconds, it didnt do that before he tried to fix it. Should I try and find a I/C board for it complete, or replace the convergence chips in case they were overheated when they tried to replace it?
I have the same TV with the same issue. Did you happen to resolve the issue? If so, would you mind emailing me at brodymaclean@gmail.com? I'm just starting to troubleshoot the issue myself.
Thanks in advance, Brody
Posted on Nov 24, 2009
My clue was the sound dying while the picture remained on-screen. That told me the audio chip was possibly suspect. If you have an o'scope, check to see if the audio chip is putting out DC on the right or left or both. The TV set will turn off if it detects this problem. Note: this is not the only reason it will shutdown; various voltage supplies that fail to hit the nominal voltages will cause the set to turn off too.
Posted on Oct 29, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Here is a tip I learned from www.TvRepairKits.com.
Remove both chips...if the TV works again then either the soldering was still bad...or you have a damaged chip. The other possible options is a missing cable or some solder that has splashed on nearby pins.
Posted on Aug 09, 2009
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
May 30, 2008 | Philips 55P8341 55" Rear Projection...
Blinking Power Light 9 Times Phillips 60PP920299
go to this link they may have your service manual for your tv they list them by chassis numbers so if you don't see it leave them an e-mail with your model number and they are very good about getting back with you
http://servicemanuals.vstore.ca/
May 09, 2008 | Philips 60PP9202 60" Rear Projection...
Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Feb 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
254 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
