Question about Arrow ET200 Electric Brad Nail Gun
It won't work nailng at a 45 degree angle - Arrow ET200 Electric Brad Nail Gun
  • 30 Answers
Sounds like there isn't enough air getting into the gun. If you can put more pressure into your air tank, try that. Hope this helps
Posted on Jul 27, 2009
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
D51822 is nailing at a 45 degree angle instead of 90 degree
Joe,
hey not sure what the d51822 brand name is I work on bostitch as a service tech. so well the obvious question with the details you've given 45 degree angle? so are they bent over to get that angle? not sure how they can come out straight and get bent. ok the nose ( where the nail comes out) is it completely flat on the board? if so I would be nearly impossible to create a 45 angle. not doubting you. I work on F28WW bostitch thinking they are similar so, check the bolts on the top (loose or damaged) or the nose its self see if it is bent. it would be only slight because otherwise the driver ( what pushes the nail in) would get jammed and not fire at all .try that first thinking the nose is bent and if its bent its junk. because cracks are next and that's when really bad things happen fast.
Nov 15, 2015 | Dewalt Heavy - Duty 31° Clipped Head...
For a 10ft radius octagon, how long should each side be?
There is probably a formula for this or other ways of doing this, but I will give it a shot.
An octagon has 8 sides (octopus has 8 legs). To make an octagon, we effectively have 8 triangles joined at the centre. In the centre, we have 8 equal angles. Since a full circle is 360 degrees, each of these angles must be 360 / 8 or 45 degrees.
Now we can just focus on one of these triangles. We have an angle of 45 degrees at the centre and two arms extending out 10 feet.
At this point, we can use the cosine law to calculate the length of the side or we can recognize that it is an isosceles triangle and work out the other angles and determine the length of the side.
Using Cosine Law, a^2= b^2 + c^2 - 2xbxc Cos A
In this case, A = 45 degrees, b = 10 feet, c=10 feet.
Good luck.
Let me know if you have any questions.
Paul
Aug 25, 2015 | Miscellaneous
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
Wen miter saw will not keep 45 degree angle
I found a wood working forum and I think that there is a discussion that may assist you with this issue: http://www.woodworking.com/forum/archive/index.php?t-4424.html
Feb 23, 2013 | Wen compound miter saw
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
What is the reference angle of 225 degrees and 15'
The answer to this is 45 degrees and 15' i.e. forty five degrees and 15 minutes. Each degree is split into 60 minutes. So that 15' would be 15/60 degrees. that means 225 degrees and 15' is equal to 225.25 degrees. The reference angle is given by = 225.25 - 180 degrees which is equal to 45.25 degrees. This is in fact 45 degrees and 15'.
Please vote for the answer!
Jun 28, 2011 | Computers & Internet
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
Arrow ET200 Electric Brad Nail Gun Logo
109 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
