Top part of agaitor turns but the bottom part doesn't turn together model LSQ8543JQ1
  • 5,911 Answers
This is commonly caused by worn agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the instructions I provided. Appliancepartspros.com carries them for about $5.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 26, 2009
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
MOTOR WILL NOT TURN ON
You have to open 3 screws on top and 4 screws on the bottom. 5 other screws from the inner bottom. Slide the rotor out from the top and unscrew the small blue switches. These switches burn and get stuck together by heat. If you can loosen them then it will still work. Clean all parts when reassembling. If it doesn't work buy parts from here: http://www.amazon.com/gp/product/B002YEJYSO/ref=sc_pgp__m_A1KB97A5SK5WKE_1?ie=UTF8&m=A1KB97A5SK5WKE&n=&s=&v=glance
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160783205909 . Ask this ebay guy if he has some more other parts. Sometimes he does.
Apr 10, 2012 | As Seen On TV Magic Bullet Food Processor
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
GE PROFILE wprb8050. agitator will not spin. I removed and found the coupler is moving left to right, just will not turn agitaor. it appears to be loose? any suggest?
If you can easily spin that agaitor coupler free by hand..its stripped and needs to be replaced. The part number for it is WH49X10042 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE
Aug 30, 2011 | GE WPRB8050D Top Load Washer
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
A dime fell in between the bottom of the washer and I can't get it out . now making noise.
hello there:
if it a top load unscrew the agaitor and lift it up and you can get your change
Aug 16, 2009 | Washing Machines
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
WHIRLPOOL TOP LOADER MODEL GSQ9669LWO
Trick or Treat. You coupler is out and I will supply a link for parts and schematic, please note part 13
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=GSQ9669LW1&productCategoryId=0153200&brandId=1198&modelName=WASHER&diagramPageId=00004&componentDescription=BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP PARTS&documentId=W0403060&backToLink=Return to Sub Components list
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wobbly agitator
If you remove the center cap from the agitator there should be either a bolt or a square recessed socket that you can attempt to tighten. The bolt is either 7/16" or 1/2". The recessed socket can be tightened using a 3/8" to 1/2" socket adapter.
Make sure the agitator is seated properly on the center post. You can accomplish this by finding the mounting bolt and loosening it enough to free the agitator on the post and push down evenly on the bottom flanges at the base of the agitator where it meets to bottom of the tub.
Try this and let me know if it helps. Post back if you need further assistance.
Feb 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Won't Work
I not sure but sounds like u have a 2 piece agitator... sounds like gears in top of agitator is stripped.. you can replace them for few bucks ... if its a 2 piece agi.
Sep 07, 2007 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
