My brother just bought a Samsung J1043 frontloader. On any wash setting, it runs for about 30 seconds {can hear water running in} & then stops. Timer stays at same time. Any thoughts?
  • peterbecky Jul 26, 2009
    No it's not new. Bought it SH. People said it worked but hadn't been used for several months. Is the control board the PCB behind the controls? If this is the problem would this need replacing?
  • peterbecky Jul 27, 2009
    Machine is totally digital (the Fussy Logic model). I will arrange to have the board checked for corrosion or other obvious problems. If we sort it out i'll let you know what it was. Thanks
    Peter.
    Brigadier General:
  • 4,088 Answers
If new, take it back to the dealer. It sounds like a control board problem.
Posted on Jul 26, 2009
  • drallim Jul 27, 2009
    In answer to the first question--yes. In answer to the second, does the control panel have a mechanical timer dial that is driven by a clock motor, or is it an entirely digital display with push-button controls? If electronic, the PCB may have green corrosion from past water entry. If nothing obvious, board will likely need to be replaced. If mechanical dial, can manually turning the dial make it begin to wash?
Samsung dish washer won't stop running event with the door open no leaks no water anywhere pump pushes water out drain hose
if you can hear it running even with door open its probably in a fault mode as this the only circumstance in which it will run with the door open, what you are hearing is the drain pump and its doing that because there is a leak in the base of the machine setting off its flood switch, if you pull the dishwasher out and lean it back you will see water run out the bottom, then you need to find where its leaking from
Dec 26, 2016 | Samsung Washing Machines
Front loader. Why does it run for about 30 seconds, then stops, beeps, and displays code e64?
Good Morning friend, thank you for your post!
I see that your Frigidaire frontload washer runs for 30 seconds, then stops, and produces an error code "E64". It appears that might be an invalid error code. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If you continue to receive the error code or a new error code please reply back. I would like to assist you further. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
When first turned on the hot water runs for less than 30 seconds and then quits. You hear a clicking sound as soon as the water stops.
This is the inlet selonoid is going bad it is behind where the water connection hoses connect to the machine.
Mar 07, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Jul 07, 2009 | Samsung WF337AA Front Load Washer
I have a samsung J1043 7kg washing machine, apon usage of it, i get an error half way threw its washing stages. on the digital screen a message 3E pops up and then im stumped, i have drain the machine,...
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Mar 17, 2009 | Samsung Washing Machines
Samsung washing machine ji453s
The ECU has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
4e code
I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
Hope this helps.
Dec 26, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
