Question about LG 32LB9D TV
Volume spontaneously lowered ans stuck at 0
Volume dropped to zero all on it's own and now LG 42" won't respond to remote control.
Turn off manually and turn on it should work better than before
Posted on Sep 22, 2009
    Problem Solver:
  • 14 Answers
Agf33694 board got same prob
Posted on Feb 28, 2010
Mitubishi WD65731 lost sound and I cannot control the volume on the TV or with Remote
check your cables and make sure the vol- button isnt physically stuck
Jul 13, 2015 | Mitsubishi WD65731
LG wont change channels with remote or manually Volume changes but scans all the way to 100 or zero depending which way its pressed help i'm stuck on BBC!!
Hello
I thinks that your LG has keylock function set to "ON". Set it "OFF" after comming to AUDIO LANGUAGE optin from its menu ehere you can set it ON and OFF. If it is ON, set it OFF. OK.
Jan 25, 2011 | LG 42LB5D 42 in. LCD Television
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Dec 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Lg will not respond to remote.
Does it work without remote OK.
You have to go to service mode menu and adjust. Only service center can help you.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
The volume on my lg ty quit working. It will not
I hate to give you the bad news, but this is not an easy fix for a do it yourself-er. you will need the internal diagram to fix this. There is an IC (intregrated circuit) chip inside that has most likely failed. I would recommend that you take it to a qualified repair shop for estimate or repair. There is really nothing in this case that you can do to fix it yourself without the proper equipment.
if you have an external jack for hooking up a surround system you may try to route the volume through this type of device and control the volume that way, but this is just a temp solution. Best of luck to you, I hope this helps.
Sep 11, 2009 | LG Televison & Video
42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
May 19, 2009 | LG 50PC1DR 50 in. Plasma HDTV
LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Apr 10, 2009 | LG 32LB9D TV
Remote control wont increase or lower volume
This sometimes happens when you've pressed DVD or another input on the LG remote. Press TV and it should work again. If you want your Sky remote to adjust the TVs volume you'll need to enter a code. See here www.satelliteonline.co.uk/sky_remote_codes.htm
Hope that helps...
Jan 23, 2008 | LG 42LC2D 42 in. LCD HDTV
LG Volume to 100 by Itself - will NOT respond to remote
It's hard to diagnose without a model, but, given the problem I would say it is a 42LC7.
If it is, then, it needs a modification in the main PCB. We used to jumper coils at first, now we have to change the main PCB.
It's less than a year old, it's under warranty.
For a servicer in your area that makes house calls:
Contact LG at:
(800) 243-0000
If you have any questions, reply to this post and I will respond.
Dec 15, 2007 | Televison & Video
LG 32LB9D TV Logo
389 people viewed this question
Computer Repairing
Computer Repairing
