Question about Garmin GPSMAP 76 GPS Receiver
Garmin 76Csx Incomplete track uploads.
When I upload tracks to my Garmin 76Csx they only partially transfer. I tried your reset suggestion; one file worked and then it resumes truncating. The file transfer indicates as complete on DNR Garmin and on the unit, but the shape is only partially captured. The same happened using GPS trackmake. I have only about 350 trackpoints saved. A second identical unit worked flawlessly.
4 Suggested Answers
  • 3422 Answers
SOURCE: Garmin Etrex vista will not
HI,
Since the problem is the PC not recognizing the device.Please try out these steps:
Try connecting your device to another USB port. Using one port all the time to connect and disconnect USB items a port can develop a range of files associated with configuring the USB connection. Some of these files might actually have been from your device connected before, or some of these configurations could be from other USB items you connect to this port. Changing ports can often lead to an immediate good connection simply because ther are no conflicting configuration files. If this does not solve your problem, we can now entertain the next process to try.
coolguy008: THIS IS A BIG ONE. This is the last thing to do. Before you try this process, please complete a full back up of your system. This is important as the next step can have side effects you did not entirely expect. AND Second, you might need your Vi Install Disk (not in all cases). What this process is about is renewing all hardware/software configurations relating to USB connections.
Here is what you do:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB device
If these suggestions are implemented and you are still have connection difficulties with your computer, there are several other things to try. If you have another XP Computer you should try connecting your device to another computer to see if the problem is a device problem or not. If it still has this problem with the next computer, it maybe be a fault of the device.
IF YOU HAVE COMPLETED ALL the above mentioned and still have a problem, you should next contact the seller of this machine for further instructions of what to do next.
Goodluck..
Posted on May 26, 2008
SOURCE: Cannot upload update
The new maps 2009 will not fit into the default c330. Purchase a 2G micros CD memory cad and load into the GPS. Then all of the maps for the lower 48 syayes, puerto Rico, and Csnada, and Alaska will now
Posted on Aug 27, 2008
SOURCE: using dnr garmin or map source how do I transfer from excel
I've just had to do this. Somewhat annoying and I'm sure there must be a quicker way. Let me know if you find one. <br /><br />Firstly you need ArcGIS or something that can create .shp files. Load the Excel file into this. In Arc you need to right click the table and display the x y data (just to make sure it's all okay). Then save as a layer. Then export as an .shp file. <br /><br />You can the open the.shp in DNRGarmin and upload to your GPS..,<br /> <!-- from fixya rte -->
Posted on Aug 15, 2010
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
8tracks not uploading properly
Mixtape at 8track artist:DJ SEVER Track:futuristic juice
Apr 16, 2012 | 8tracks.com
My Garmin Etrex Summit records tracklogs and shows them on the screen but when I upload them to my PC all tracks show as 0 miles, 0 altitude etc
2 possible reasons.
Either memory is full.
Try remove all data from history, and have a small run.
It should be OK then on PC upload.
If not OK, only hard reset can cleanup device, and return to factory settings.
Consult your manual for hard reset instructions.
Oct 04, 2010 | Garmin eTrex Summit GPS Receiver
While down loading maps the 76CSX just quit. The batteries are good. When I turn on the GPS it starts then fads away like there is no power, yet I have tryed 2 sets of new batteries.
It sounds like a corrupted upload. Reset the unit and retry the upload.
Usually reset is done by pushing page and enter while powering up
Apr 22, 2009 | Garmin GPSMAP 76 GPS Receiver
Problem downloading maps to my 76csx
With unit off, press and hold ENTER and PAGE while powering on to perform a master reset.
Doing a master reset will erase and data in the device and restore it to factory defaults. So if you have any waypoints/tracks/routes you may want to back them up first.
You may want to update your mapsoure software first and see if that helps the issue. If not reinstall the software.
oh and double check your micro SD card to make sure its not damaged and is inserted all the way in.
Jan 18, 2009 | Garmin GPSMAP 76 GPS Receiver
Mp3 transfer to media player
The U900 handles only 2gb memory cards !
Oct 06, 2008 | Samsung U900 Soul Cellular Phone
Gps repair service
You find details to get a service in your area on last pages of your user manual.
Jul 12, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
'Library Full' Error when transferring files to Zen.
the zen uses other areas for data storage and stuff.
best to reformat and not use so many folders.
Oct 21, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Garmin GPSMAP 76 GPS Receiver Logo
132 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
