Question about Roper Washing Machines
Our Roper washer will wash the clothes, but it will not spin them all the way out. The clothes are soaked at the end of the cycle.
Washer roper 8280871
oil leaks wont spin fast
Posted on Aug 02, 2009
Maytag317
  • 1136 Answers
SOURCE: washer wont spin at end of cycle
Hi, it sounds like the coupler or lid switch is bad. Do you hear the motor running during these cycles?
If you do, the coupler has gone bad. Here are the instruction on how to change the coupler. Part# 285852
Normal 0 Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Normal 0 How to replace a coupler.
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
I know this is lengthy but I hope it helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 25, 2009
mark_37388
  • 100 Answers
SOURCE: spin cycle not working,
sounds like you have a broken motor coupling between the motor and transmission
Posted on Mar 30, 2009
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
  • 401 Answers
SOURCE: my Roper washer will not spin on the spin cycle.
IF ITS A TOP LOADER YOU MAY HAVE A BROKEN LID SWITCH. LOOK DON THE HOLE IN THE TOP WHERE THE LID PIN GOES CAN YOU SEE THE LID SWITCH ARM? IF ITS NOT FLUSH WITH THE HOLE ITS BROKEN. SOMETIMES YOU CAN STICK SOMETHING THROUGH THE HOLE TO ACTIVATE IT
Posted on Jan 15, 2010
  • 105 Answers
SOURCE: my clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Posted on Feb 06, 2010
I have a roper Washing machine and it will wash clothes and do all the cycles but at the end of spin cycle when it's done the clothes are still soaked
99% probability that you have a blocked pump. I don't know the particular model but most have access to the pump either through a small door on the front at the bottom, or hidden behind the kick plate that runs along the bottom of the machine
Sep 22, 2015 | Roper Washing Machines
No spin cycle - cloths soaking wet - motor runs continuously - hot burn smell
if the washer drains the drive cuppler it bad let me know if draing can walk you threw how to replace
Jun 24, 2011 | Roper RAS8445KQ Top Load Washer
My clothes are soak and wet after the spinning cycle ends
Feb 06, 2010 | Washing Machines
My Roper washer will not spin on the spin cycle.
Jan 15, 2010 | Washing Machines
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
356 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
