Question about Garden
Murray riding mower
After shuting off my murray riding mower, it will not start up without charging battery, which is new...and it struggles to turn over.
    Scholar:
  • 173 Answers
You may have to change the magneto.
That's the return circuit which charges the battery.
Posted on Jul 27, 2009
Murray riding mower was left all winter battery charged doesn't even turn over
test battery is it holding charge --are connections clean
Apr 28, 2017 | Cars & Trucks
I am looking for a parts and repair manual for a 2004 model #385016X78A Murray ride on mower.
Murray went out of business and was bought out by new outfit. Do not know if new Murray (kept the name) manufacturer will support the older products produced previously. You can always check and cross your fingers.
Sep 29, 2016 | Murray Garden
How do you check a ignition switch on a murray riding lawn mower to make sure it is operating properly?
You will need a multimeter... then you will need to check each wire port to see if voltage is registering . I would also disconnect the safety switch under the seat or.. plus put the emergency brake on as well... anything and all that will stop the engine from getting the signal to the coil to start up..
Nov 01, 2015 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray select riding mower model 309000x8NA won't start?
check ground wire and posts for continuity between battery and starter, if you don't have a multimeter, remove, clean and replace all ground connectins. If that isn't it and you are sure that your battery is good and you've got good juice to the starter than the starter needs op-checked, remove it from the engine and engage it, if gear shifts out and spins rapidly you may have engine problem. Hope this helps...
Mar 28, 2010 | Garden
Murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Aug 11, 2009 | Briggs & Stratton Garden
Murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Sep 06, 2008 | Garden
Garden Logo
344 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
