Question about Maytag Neptune MDG5500AW Gas Dryer
Intermittently won't "flame on"
When you can hear the flame ignite, then everything seems ok.
    Scholar:
  • 76 Answers
Try changing you gas valve coils. Take the front panel off and look for you gas valve...theres is a plate that id holding 2 black things, those are you gas valve coils. try changiing those...one of them has a metal sleeve you will need that..make sure you dont throw it away..sometime the metal sleeve will come off when you slide the ould coil out...make sure you do one at a time ane look for tha metal sleeve because you want to kno which shaft ot cam out from and slide it back on the shaft. them just slide the new ones on, making sure you put the right ones in the right spot..(just look at the prongs for reference) then youll kno which goes where..hope this helps//
Posted on Jul 27, 2009
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
My flame keeps going out. i can press the reset button and some times it will work for a week sometimes only 30 seconds. It is an intermittent igniter. The flame seems to "roll back" when it...
Your GMS unit should not be intermittent ignition but direct electronic ignition. In any case the flame should never roll out of the chamber. There can be a few reasons for the roll out but sometimes a good cleaning of the heat exchanger and a combustion analysis can cure that. The intermittent flame issue is probably a dirty flame sensor and can be cleaned with light sand paper or steel wool. Be careful not to touch the igniter only the flame sensor. It is usually on the opposite side of the burners from the ignition source. Hope this helps :)
Jan 03, 2011 | Goodman GMS90703BXA Heater
Brand new unit model G6A-8E. when i first hit the switch it comes on fine and heats water. at a later point (and it seems to be intermittant), when it goes to re-ignite to reheat the water it will not...
Check and adjust igniter probe(s) so that they are in front of the flame good. When you say it goes to re-ignite, can you hear, or see spark happening at igniter, but burner just won't catch?
Nov 01, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Raypack pool/spa heater works intermittently
You can try pulling your pilot assembly out and clean it. Sometimes it will get sooted up and cause the sensor to short so the heater get's a falce reading and shuts the heater down. Then sometimes the heater will start and sometimes it won't. If this dosen't help check the ignition wire for any cracks or anyplace it may be shorting. Good luck.
Feb 17, 2010 | Raypak Versa 130,000 Btu Above Ground...
Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Aug 23, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Heater problem
i concur, when flame is not sensed gas valve closes
Jun 13, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Gas dryer don't heat, pilot ok
The ignitor is coming on so that means you have power to the gas assembly. Next the flame sensor should shut down the ignitor when the bi-metal inside it bends from the heat. This kills power to the ignitor, which allows for the power to activate the coils. The coils snatch open the gas valve and allow for ignition. The raw gas hits that screaming hot ignitor and ignites into a glorious flame, raising the temperature inside the drum. While that flame is on, the control thermostat is monitoring the heat within the drum. When the temperature gets to a round 140 F then the power gets killed to the gas assembly by the control thermostat. If all of that seems to be happening for say, the first time, then suddenly the ignitor comes on then shuts down and no flame comes out, then you have weak and intermittant coils. Replace these puppys:
Dec 16, 2008 | Dryers
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
My bosch 21E (infinity style) hot water system has an intermittant fault where the flame does not appear to be able to stay on (or properly light). Once water is started to the unit I can hear the ignitor...
moisture is getting into circuit board, usaully this sealed in a jell which keeps the board protected from any kind off dust,moisture etc which would comprimise the thinking side off the unit. a bosch engineer should be able to do a diagnostics on site.
Aug 08, 2008 | Heating & Cooling
Maytag Neptune MDG5500AW Gas Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
