Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse 1080p won't boot up
I turn on the tv and it displays the Westinghouse logo for a moment, then drops to off. The little orange light stays on. When it is working right, it goes to blue. It worked great for the past 3 months. We did try to reset the channels this morning; where the tv scans for signals, then skips the "no-signal" channels. It worked after this, then we turned it off and it has not worked since. We have tried the button on the tv itself as well as the remote and unplugging and re-plugging in the tv.
SOURCE: My Westinghouse won't turn on, please help!
Ok, believe it or not, i am a 13 year old boy. ya i know whatever i oviousely know the problem and u don't so don't think i'm stupid. i found a westinghouse lcd at a dump, and thought i should try it out. it worked the very first time, and then when i unplugged it and used it with another plug, it wouldn't turn on. LISTEN GUYS, WE ALL HAVE THE SAME PROBLEM, AND DID THE SAME THING. WE ALL *UNPLUGGED THE TV*! this is that you have to do: unplug the AC adapter or power adapter from the tv, and from the wall. most likely its not the cord that is the problem. the tv needs to cool. leave the tv with on wires in it for about 3 hours, and then try again. if atleast 5 hours pasts and it still wont work, then you have blown a fuse.
Posted on Nov 29, 2008
SOURCE: Westinghouse LTV-19W6 TV Won't change channels
I had the same the problem.  My tv would not change channels.  I had to run the tv through my dvd player to be able to view my cable channels.  The one solution listed did work for me.  Set your source to tv...press menu on your remote control...go down to the 4th icon...press the right arrow...move down to CH Auto Scan and press the right arrow.  The tv will scan for channels and once complete I was able to change channels again.
Posted on Jan 10, 2009
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
panchal643Ja
  • 243 Answers
SOURCE: tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Posted on Jan 23, 2010
TV booting problems
Probably a power supply problem. It is trying to start but can't.
Jan 14, 2014 | Toshiba 55l6200u 55es Smart 1080p/120hz...
55" westinghouse vr-5525z Sound but no picture
Check its back-light inverter board and back-light CCFL lamps. If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
May 02, 2013 | Westinghouse 55" 1080p 120hz LCD HDTV -...
My 42 inch westinghouse wont turn onDTV 1080p TX-42F430S
If you are referring to that you are unable to select the the 1080p setting in the TV menu, first try changing the aspect ratio in the TV Menu.
If that does not do it, you have to change the display setting ion your device, if you can not or it does not have 1080p the problem is that resolution is unsupported by your device
Jun 07, 2012 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Screen go back to black after the westinghouse logo displays.
Westinghouse? A model number might help me help you---does sound remain or never make it on?
Mar 14, 2012 | Televison & Video
Westinghouse tv won`t turn on. blue light is lit
westinghouse flat screen ...blue light on lower part...can not get to stay on tv and no sound...what button so i push to go back to tv
Feb 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
100 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
