Question about Sony Computers & Internet
New hard drive problem
I just bought a new hard drive to replace my old one, but ive run into a problem. When it is formatting, around 5% it will turn off and then the power light will turn red and blink until i touch it. The new hard drive meets all the requirements for the ps3 and has the same RPM. Please help!
    Scholar:
  • 41 Answers
There sounds like there is something wrong with the drive. If it is a SATA notebook hard drive with the same RPM (5400), there shouldn't be any issues at all.
Double check this by reformatting the old one you replaced it with (as long as you have your data backed up). If that reformat goes smoothly, get your new drive replaced.
Posted on Jul 27, 2009
Defragment/clean-up external HD
Hello Anonymous
Make sure you have backed up all the files you need to keep.
Store them on the computer if you have the space... until you put them back on the clean Hard Drive.
Your drive would be seven years old now. So... it would be a wise move to do a security type format to test the drives integrity before you loose your backups. Many Drives don't last seven years...
320GB is also pretty small these days. Suggest you use the old drive for eg. "Movies" and buy a new Hard Drive for your Backups as this drive may fail at any time.
Murphy's Law says that will be when you need it the most!
A 3.5 inch Drive (uses 5v&12v) and is more robust & faster than your 2.5" pocket type drives that run on 5 volts only. Also, look for a USB 3 or FireWire Port connector as these will ensure compatibility & speed on future computers. USB 1&2 are slow on large files.
DeFragging only shuffles the empty space around. Lining it up sequentially so that it's faster at accessing the data.
Re Formatting wipes the directory off the drive making it appear that you have a new clean drive. Previous files then get overwritten.
Do a security erase if you want to clean all data from the drive & test the drive for faults. This will return all available space available to you as an empty drive.
On a Mac, use Disk Utility. Choose Fat32 to allow interchangeability with Mac <> PC or "Mac OS Extended (Journaled)" for Mac Bootable Disks.
On a PC use Disk Management for a quick format to Fat32 or NTFS for Windows Boot. Or See Here for full details:
http://pcsupport.about.com/od/tipstricks/f/format-hard-drive.htm
Drives are so inexpensive these days. You can pick up a 1Terrabyte drive for $99 here. Format & test the drive before putting it to use on your computer. This will be one of the few times you will get to test & experiment with the drive before you put your data on it.
You can always use a USB Memory Stick as a pretend Hard Drive to experiment with & test the formatting procedure. They use the same Partition & Format utilities as a regular Hard Drive.
Cheers
Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 06, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
New hard drive/how to install Windows
the new hard drive has to be Formatted using the format command. look up dos format command or a utility program. then you have to reinstall Windows ?(whatever you had i guess) on the pc. any drivers disk for that pc needs to run after you format the hard drive and before installing the Windows operating system. exactly how depends. go on the HOW TO search site to find the exact steps -
Nov 20, 2013 | Dell Inspiron Computers & Internet
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Hard disk faulty how to replace
The online guide is here:
http://www.scribd.com/doc/7994162/Compaq-Presario-M2000-Maintenance-and-Service-Guide
I would go to (page 2-5 of the manual above) first and run a Hard Drive test from the Tools menu, before replacing.
Then go to replacement procedures (Page 5-7 of the manual) and it will instruct you, it is very simple, usually taking out two screws, removing the caddy (plastic holder). You then unscrew the old hard drive from the caddy (four screws) and then screw in the new hard drive (four again), slide it in, screw the caddy in (two screws) and voila', your new hard drive is installed.
This does NOT include instructions on how to backup your files, re-install your software or anything OTHER than replacing the physical hard drive.
You will need to format the new drive and install an operating system and software.
If you need further instructions, please ask.
Sep 07, 2010 | Compaq Presario M2000 Notebook
I just bought a new HP pavilion laptop (because the Nvidia graphics chipset on my Dell went belly up). I pulled the Dell hard drive out and placed it into an external case intending to copy the data onto...
Hi Maltomeal
it seems you know your way around notebooks.
My first suggestion is to take the new hard drive out, and put the old one into the new computer to see if it will at least boot up.
Since I don't know the operating system or the type of format that was on your old hard drive, it is possible that the current operating system you are using will not recognize the old one.
If the hard drive boots up, and it may not recognize some of the drivers because its a different computer configuration, you should still be able to backup to a thumb drive.
If the hard drive does not boot up, then your hard drive has lost its information. You might need to take the hard drive to a data recovery company like ontrack.
thanks adi
Jan 11, 2010 | Office Equipment & Supplies
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
My HP Pavillion crashed. The hard drive is the sp1604n. I bought a new computer but want to tranfer or copy the picture files on the old (sp1604n) drive to my new computer. The old computer was windows xp...
In your new computer go to all programs then to your user guide. Once there open the guide and follow prompts to transfer data from old computer to your new one. Some stuff may have to be reformatted do work with Vista.
Sep 26, 2009 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
I just wanna know how to replace an acer laptop hard drive with a bigger one
Usually you
1) purchase the new hard drive
2) look around the base of your laptop to find where the HDD is, if you look at the manual which im sure acer will have on its site it will show you
3) usually 1 or 2 screws are unscrewed and you slide out the hard drive, it will be in a special holder
4) unscrew the old hard drive and insert the new one and secure it in place like the old one.
5) insert, re-do screws up, turn on laptop.
this new hard drive wont have any information on it so you will need to reinstall windows on that drive.
Jun 06, 2008 | Acer Computers & Internet
Computers & Internet Logo
108 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
