Question about Whirlpool MH1150XMQ Microwave Oven
How to remove the microwave oven
Over the stove microware oven, we have removed screws, will not come out/ off the wall.... are there any special unseen screws or brackets that we are not aware of?
  • Anonymous Dec 27, 2007
    I had a similar problem. On certain models, there is an additional safety retaining clip. Remove grill above door and you will see it. Pull on it and it will release the microwave.
  • Whirlpool Master
  • 9,098 Answers
The installation instructions should help:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208184732.pdf
If that URL gives you troulbe, look it up here: http://whirlpool.com/custserv/index.jsp
Posted on Nov 22, 2007
  • William Miller
    William Miller Dec 01, 2007
    We're happy to help and we appreciate your thoughtful rating of our answer.
How do i remove a over the stove microwave?
On a 1-10 scale- this is a 2.
place a cardboard box on the stove to support the microwave once it is free.
Remove power cord from the outlet in the cabinet over the microwave.
In the cabinet over the microwave, locate the 2 mounting screws.
Loosen each one about 6 turns- the microwave should drop down in the front by about 1/2 inch.
Once loose, you can remove both screws completely and allow the front of the oven to rest on the cardboard box.
While supporting the front of the microwave,have a helper remove the cardboard box.
Tricky part...while supporting the front - angled slightly down, lift hard under the rear of the microwave and pull toward you.
Have a helper feed the power cord through the upper cabinet bas as you bring the microwave toward you and slightly down.
Place the microwave on the counter- with a towel in place to prevent scratching the counter.
remove the rear-wall mounted support bracket.
Done
Apr 27, 2014 | Maytag MMV4205 Microwave Oven
I need to remove a spacemaker microwave from over the stove. I have removed all the screws that I can see and it's still rock solid. Suggestions?
As I recall the only 2 or 3 long screws that you need to remove are in the cabinet directly above the microwave. You will also, of course need to unplug the microwave above it as well. Is should now hinge down, as the back edge hooks onto a mounting plate on back wall.
Jun 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do i remove build in micowave from top stove ?
On the cabinet above the microwave there will be two screws. Hold the microwave with one hand while unscrewing the screws with the other. Once the screws are removed, the microwave will lean forward but not come off the wall. Once you have a good grip on the microwave, lift up towards the back of the microwave and it will come away from the wall.
Sep 24, 2009 | GE Microwave Ovens
I need to know how to uninstall a GE spacemaker microwave oven model JVM250av001...any one out there know how..?
Put padding on the floor near by for a landing zone. Disconnect the power in the cabinet above. There are two screws in the upper cabinet that support the front. There is a wall plate that supports the back. When the two front screws are removed you will need to be supporting the microhood or it will fall. A strong assistant is nice to have. I like to have the stove out of the way so I can get under the microwave to support it. Once the front two screws are removed, tip the front down, pull the cord out of the upper cabinet. Then lift the back slightly to remove it from the channel on the wall bracket. Set it down Done.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do i take it down?
If possible, to make the job a LOT EASIER, pull the stove out from the wall, so you can get under the mocrowave.
DISCONNECT THE POWER.
You'll have to remove the unit from the case.
Remove the screws from the bottom and it should slide out. Then, remove the mounting screws. It's best to have a helper, it isn't always in a good position.
May 25, 2009 | Kenmore 63792 Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
HOW DO YOU REMOVE AN OVER THE STOVE GE MICROWAVE ?
open doors of your cabinet above the microwave, look carefully toward the front you will see two screws one on either side, remove theses screws while a helper holds bottom of microwave, after screws are removed lift up on rear of microwave it will slide up and out of a rear clip mounted on the back wall. remove wall bracket and job is complete. oh yeah unplug microwave, or turn off circuitbreaker first. easy as 1, 2, 3. hope this helps.
Nov 05, 2008 | Microwave Ovens
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
536 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
