Question about RCA M4204 MP3 Player
My Mp3 player freezes and the battery slows down all the time, now on top of everything it won't turn on or charge. I've tried many different computer outlets to charge it, but it simply won't charge. I really don't want to throw it away seeing that it also has tracks I've recorded on it. thank you
    Problem Solver:
  • 10 Answers
Try pressing the restart button on the bottom of the mp3 player
Posted on Jul 27, 2009
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
My Philips GoGear MP3 won't turn on. Is there any way it can get fixed? I've tried resetting it but nothing happens.
(I "ASSUME" you charged it, or tried to). HOW OLD is your MP3 player??
If it's pushing 2yrs old, or played/used on a fairly regular/daily basis,
.....YOU MAY JUST NEED A NEW BATTERY.
Carefully peel up the UPC code strip on back of player. (There is a tiny screw underneath it)
Carefully remove screw. (The snap notches are 'L' shaped inside the edges of the case).
Gently slide/pry open the backside of the case, taking care NOT to break the snap notches.
Open case, REMOVE BATTERY. FIND/MATCH BATTERY TYPE. (look in WATCH batteries).
Place the new battery in player. Close case, restart/turn on player.
Nov 04, 2011 | Philips GOGEAR SA6045 MP3 Player
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
I have an RCA mp3 player M4304 and the battery says full, but it shuts down and reads "low battery" after 10 minutes. Can the battery be changed? If so, how?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Jul 11, 2011 | RCA M4304 Digital Media Player
After charging your portable media player overnight, you turn it on only to find that it is reporting a low battery. Seconds later, it shuts off automatically. What might be wrong
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Apple iPod shuffle MP3 Player
My literati ereader will not charge. i kept plugging it in to charge and it would never connect and now the battery has completely died and the reader won't turn on.
If you've got any wiggle in the connector on the device, it's broken lose. If not, you've got bigger issues. Either way, it's a trip to the shop, or replacement time.
Jul 06, 2011 | Audio Players & Recorders
Coby MP-C582 Will not turn on
These players are notorious for battery problems. Charge it all night and you just might get 30 minutes of use out of it before the battery dies. Make sure the slider switch next to the power button on top isn't in the "lock" position as the unit will not power up if it is. I recommend getting a 12 volt car charging plug for it and getting real aquainted with the tiny reset button on the battery side of it. You can get a plug for about $6 that will charge it through the usb cable that came with the player.
Feb 27, 2008 | Coby MP-C7085 MP3 Player
RCA M4204  MP3 Player Logo
95 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
