Question about Locks & Locksmithing
Eureka vacuum cleaner electolux home care products,ltd bloomington,IL 61701 model 4709 type az volts 120 amps 12 hz 60 household type menager serial no 0915003709 cannot remove green cap from tank to remove filter for replacement or cleaning
  • rrussell43 Jul 27, 2009
    the solution was stated clearly and easy to follow
    this customer is completely satisfied with the quality of all aspects of his dealings with Fixya
  • 2,200 Answers
Hi
You must remove the tank from the hoover - you cannot remove the cap from the tank.
The tank is only secured to the hoover at the top by a plastic tab that inserts into the body of the hoover. Pull the top towards you and it will come away.
The filter is at the bottom of the hoover body - you will see it when you remove the tank.
I have included these two links which show diagrams of where the filter is and how the tank is secured to the body.
http://www.eureka.com/service/manuals/76091.pdf
http://www.eureka.com/service/manuals/81156.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 26, 2009
Does anyone have the specs for this model, HxWxD
Watts (W) 1300 W
Current (A) 12 A
Volts (V) 120 V
Frequency (Hz) 60 Hz
Tub type TallTub
Plug type 120V-3 prong
Dimensions & Weight
Overall appliance dimensions (HxWxD) (in) 34 1/8 '' x 23 9/16 '' x 22 7/16 ''
Required cutout size (HxWxD) (in) 34 1/8 '' x 24 '' x 24 ''
Product packaging dimensions (HxWxD) (in) 36 13/16'' x 26'' x 28''
Length inlet hose (in) 55''
Gross weight (lbs) 123 lbs
Net weight (lbs) 118 lbs
Of course you don't mention which model you have ??
Mar 18, 2016 | Bosch SHX68P05UC Dishwasher
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
Le moteur de mon aspirateur duo vac model 3200 refuse de démarrer, cette aspirateur à plus de 10 ans et a toujours fonctioné, La semaine dernière le moteur a...
Bonjour M. Grenier, le probleme ce situe dans la carte électronique de votre aspirateur central Duo Vac. C'est probablement le relais qui est défectueux. Il peut rester en position ''on'' ou autant en position ''off'' lorsqu il devient capricieux. Contactez nous au www.aspirateursenligne.com pour des renseignements et les pièces
Bonne chance
Nov 16, 2010 | Microwave Ovens
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
How to change the belt on a Eureka Mighty Mite II.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Generic problem for all Vacuums
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Eureka Wide Track Superlite
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12164&thid=669867
Posted by mjtnm on Jun 14, 2008
The brush motor went out. Is it possible to buy one and splice it to the existing wires? Where can I buy one? The vacuum is model #409 the number on the dead motor is: DA-20L-2001, 17.5V DC AOM 4293S
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 421A EZ Kleen Bagless Stick Vacuum. Yes, you can replace the power nozzle motor in the head of the Eureka 421A EZ Kleen Bagless Stick Vacuum by either contacting the local vacuum cleaner dealer in your area or to contact the Eureka factory and ask for cust serv or tech support or parts and they will direct you to the correct dept to order the P/N motor so that you can install it and get on with your cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Jun 14, 2008 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Eureka sanitaire SC412 thermal reset
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658043 Generic problem for all Vacuums
Posted by 5star on Jun 09, 200
I need to reset the thermal reset button. I have never opened by back pack vacuum before. Does it have a particular color and does it have to be reset to a particular point or do I just press a button?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka / Sanitaire SC412 Thermal Reset. I would contact the manufacturer to see if your particular model # has one, just give them the model # and the serial #. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service Dept for U.S.
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Locks & Locksmithing Logo
37 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
