Question about McCulloch FH160G Pressure Washer
Parts Where can I get replacement parts for McCulloch 1600 psi jet washer? The adapter at the bottom going from the hose to the body is broke.
  • 2,176 Answers
Go to McCullochpower.com and under power equipt click on pressure washer follow the links till you get to page about ordering parts and you will need your exact model number but the parts can be ordered online or there is a link to find a dealer near you. Let me know if you still need more help
Posted on Jul 26, 2009
I have a broken plastic inlet valve for the water supply. It has standard female hose threads on one end and the same thread as the pressure hose has on the other end where can I find a replacement? It has...
May I suggest replacing this plastic part for metal parts (parts for 16 year old unit most likely not available) available thru www.pwmall.com or other pressure washer parts houses. Look thu parts listings and purchase adapters with correct thread /fitting type for your application. They will assist you with your purchase. As an example, view the following link for adapters.
http://www.pwmall.com/s-20873-twist-connect-couplings.aspx
Northern tools also has a very good selection of fittings to solve your problem (Northern tools Co are in most larger cities). www.northerntool.com
Good luck
Apr 17, 2011 | McCulloch Garden
Replacing a broken component on my McCulloch FH180B
Mc Culloch service centre Check the phone books pages in your country of origin ( or on the net). Your local hardware or distributor should be able to direct you to the service centre.
Cheap part ( $5) but they have a minimum labour cost of $100. So ask first if you can just buy the part and DIY
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | McCulloch MCCFH180B Electric Pressure...
I own a McCulloch Model FH130B Hi Pressure Jet Washer and need to replace the hose. Where can I find the replacement parts? I live in Sherwood Park, Alberta, Canada. RP
A real good/knowledgeable hose shop in your area should be able to fab a replacement. Otherwise possibly check at a local contractor store like that of home depot for replacement short of investigating the mfg web site for authorized repair/service centers in your area.
Jan 16, 2010 | McCulloch FH180A Electric Pressure Washer
Where can i get a new hose for a1600 psi jet washer? Hose has a leak in it and we are not having any luck finding a replacement locally. Washer was purchased at either walmart or Canadian Tire.
I have an older Karcher Pressure Washer and I am unable to find the model number. This is the info that I have: 79C2, Volume 1.9, Pressure 1400, Serial # 800983493B, 120 Bar, 60 degree C,
QC506-877. I need the model # to order a replace gun and/or wand. thank you
Jul 14, 2009 | McCulloch FHH18A Electric Pressure Washer
Pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
May 25, 2009 | McCulloch MCCFH180B Electric Pressure...
I need a McCulloch FH140A pressure washer spray nozzle
you will have to replace the wand which you can purchase from a reputable hardware store
Apr 08, 2009 | McCulloch 1400 Psi Electric Pressure...
McCulloch FH160G Pressure Washer Logo
621 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
