Question about GE Refrigerators
Not cooling and temperature lights are off
Refrigerator is not cooling and temperature digital lights are off
  • GE Master
  • 1,606 Answers
If you have a GE , then the main control board is bad . Model and brand would have been helpful .
Posted on Jul 27, 2009
Refrigerator not cooling
When the lights are on, and still not freezing I think of two things, A thermostat or the compressor (or both, but that is unlikely)
A digital thermostat also he's a temperature feeler and a switch and it also can be defect. When you measure a voltage coming to the compressor and it does not start it is the motor. When the motor runs and it is still not cooling, perhaps the cooling fluid (used to be Freon) leaked out. So some things to check
Feb 05, 2015 | Traulsen Refrigerators
Subzero freezer works refrigerator lights off and not cooling
You probably have a bad light switch.it's the one on the left up top. If you look closely you can still read the temperature in the display to tell if it's cooling.
Jun 29, 2014 | Sub-Zero 690 Side by Side Refrigerator
Frigidaire refrigerator model ffhs2313lpo
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
Apr 28, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Temperature control not lit, not cooling, not freezing
What is the model number of your unit?
Nov 02, 2012 | Refrigerators
The freezer is fine, but the refrigerator is too warm (set at 37...now at 52). The temperature control has power (it lights up)
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 18, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
