Question about TruTech PVS31170S1W 17 in. LCD Television
My DVD player does not read any dvd disks. Instead, it says, "invalid disk." How do I fix this?
  • kayc1186 Jul 26, 2009
    Thank you so much! If cleaning the laser doesn't work, how much is the repair?
    Thank you so much! I'm going to try this, but if cleaning the laser doesn't work, how much is the repair going to be?
    President:
  • 2,923 Answers
Sounds like the laser could be bad. But you may try cleaning the laser first before sending it to a repair tech. Sensor cleaner is cheap compared to the price of the laser.
Check the link below for the instruction on how to clean the laser:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Check the link below to see the laser cleaner:
http://www.amazon.com/Maxell-DVD-LC-DVD-Lens-Cleaner/dp/B00000JPPI
Hope these helps and have a great day!
Posted on Jul 26, 2009
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
Invalid disc reading
I find that I get the Invalid disk message most likely when I use a DVD-R disk. So now I use only DVD+R for this machine. I have also read somewhere that the problem could be solved by using a Laser Lens Cleaner Cleaning disk.
Sep 15, 2011 | Lite On LVC-9016G DVD Recorder/VCR
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Program says dvd+r incompatible with toshiba dvd player
Some DVD players will read 'DVD-R' ("minus-R") disks.
Some DVD players will read 'DVD+R' ("minus+R") disks.
Some DVD players will read "both" types of disks.
So, if you're burning onto a DVD+R disk, you won't be able to "play" the disk on your Toshiba DVD-player.
Instead, buy "blank" DVD-R disks, and write on them.
Apr 05, 2010 | Computers & Internet
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
Invalid Disk
Sounds like a damaged disk or a dirty laser lens.
Clean the disk, and have the optical drive professionally cleaned. Your laser could also be burning out as well. :(
Hope this helped out.
-Pro Hack
Oct 30, 2008 | TruTech PVS12701 Portable DVD Player
Venturer portable dvd player
it is dirty needs a good cleaning or the laser needs to be replaced
Jun 20, 2008 | Venturer PVS177W Portable DVD Player
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Portable DVD player doesn't recognize DVD disks any more
Laser read head burned out or internally disconnected.
Sep 18, 2017 | Televison & Video
Wont read dvd
won't read disk...tried alchol om lens....i'm in arlington tx. any place i can take this to get fixed in my area? dredlock89@yahoo.com
Feb 19, 2007 | Durabrand DUR7 Portable DVD Player
TruTech PVS31170S1W 17 in. LCD Television Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
