Question about Mitsubishi MS24WN Air Conditioner
I HAVE A OLDER MODEL MR SLIM MS09NW-WATER LEAKING ALOT WHAT CAN I DO MYSELF TO FIX?
manhandy
  • 146 Answers
SOURCE: Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Posted on Jul 18, 2009
  • 6 Answers
SOURCE: The Mr. Slim is leaking water
is there water coming from the drain line outside? If not take a garden hose and back flush the drain line there may be some sludge in the line. DO NOT FLOOD YOUR HOUSE short quick burst's
Posted on Jul 26, 2009
SOURCE: I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Posted on May 05, 2010
  • 9 Answers
SOURCE: My Mr SLim Model MS12TN indoor unit is leaking, I
well this units have sort of a goo like foam tape that holds the coil in place it sounds to me that part of that is allready damage and the water is running down the coil and out of the drain pan the only way to fix it is to replace that foam tape.
Posted on Jun 03, 2010
  • 167 Answers
SOURCE: Water is leaking inside the house
The drain that should be carrying the condensate water outside is stopped up. Compressed air works well to clear the drain.
Posted on Jun 22, 2010
Leaking water
sounds like the drain is blocked or possibly the drip tray has a crack in it
Aug 01, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
My evaporator is leaking inside the house. It is a steady drip. Is there some way for me to fix this myself?
Attach a hose to the drip pan to lead the condensation somewhere else (eg. outside, the drain, a pot). If it was properly installed, it should already have a drain hose. The hose might be clogged.
Aug 08, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I need an evaporator control board for Mr. Slim Model MS 18 NN Where can I order this item ? Please help. C.J. Leslie
Here you go
http://www.expertappliance.com/mitsubishi-mr-slim-parts.html
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Our Mitsubishi Mr. Slim split a/c unit is wall mounted and is leaking badly from the bottom left side inside our home. We have to use a bucket underneath the unit to catch the leak. Please help us to fix...
Dec 06, 2010 | Heating & Cooling
My Mr SLim Model MS12TN indoor unit is leaking, I cleared the outside hose, I have cleaned filters, run dy mode, what causes this. I pourchased unit in May 2005
Jun 02, 2010 | Mitsubishi MS15TN Air Conditioner
Hi I have a Mr Slim Mitsubishi Aircon. I am not
my dear i am so so sorry but that oily liquid is freon an that will take a tech to come an find the leak an repair problem i wish i could coach you though to fix problem but i know you dont have the tools to fix it so hope i completed your question
May 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
The Mr. Slim is leaking water. It is 103 out.
Jul 23, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi mr. slim is leaking water
you dont have enough fall creating a water trap which breeds bacteria into a green slim ball blocking drain you need to chop more brick wood what ever the pipe drain go through so there is very good fall problem solved the pipe being blocked causes water to back up these heads can loose 4 ltrs an hr in qld not sure on other state hope i was some help
regards john
john@topnotchelectrics.com.au
Jun 08, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
381 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
