Question about HP Ep7120 Multimedia Projector
Menu selections I am using a Mac Pro laptop and trying to view a video. I am unable to use any of the controls on the projector and the video is a very stark color
Re: Menu selections
I was able to solve a similar problem by unplugging the unit for about a minute and plugging it back in.
Posted on Jan 10, 2008
0 characters
3 Points
Our club owns a Canon LV-7240 which has worked OK. Last night we showed an NTSC DVD from Europe and no red showed. We could see what the colours ought to be on the laptop screen. On the big screen,...
Can't answer for the menu issues, but I can garuntee this is not a problem with brightness, contrast or sharpness, and very unlikely that you'll find a solution in the menu. What is likely is that the VGA wasn't plugged in properly initially. When the signal is going down the VGA it's broken up into 5 seperate signals, Red, Green, Blue and 2 sync signals. What is likely is that the green and blue pins havn't properly made contact either inside the projector or inside the laptop. This would also explain why it worked when you tried later because it made the connection properly. I would suggest trying again with the same laptop, if it does it again, try another PC without moving the projector or the VGA connector that's plugged into the projector. This will atleast narrow down your problem, but it doesn't sound like a problem with the projector to me. Also try plugging the laptop that wasn't working properly into a monitor (this will test the laptop)
Mar 25, 2011 | Canon LV-7240 Multimedia Projector
I've had this Optoma PK102 for about year and am not able to get desired results! What cable do I need to connect my Optoma PK102 and Apple ITouch. I have 2 Problems. Problem 1- I am unable to view...
Welcome to Fixya. You need to put the file on the projector for you to view the PPT presentation.
You need to connect a USB cable shown on the image below. If you don't have the cable i suggest you purchase on just bring the projector to a store to have a compatible usb cable.
Use the link below for the manual and more info about the product.
Thanks for using Fixya
Mar 13, 2011 | Optoma Multimedia Projectors
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here:
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
PC expands and shrinks text/images when connected to projector
the resolution doesn't match. go into the menu on the projector and select auto image. this should clear up the resolution prob.
Jun 24, 2009 | InFocus LP 425 Multimedia Projector
I have a MacBook Pro and a XR-30s sharp projector. When using the DVI port on the Mac to DVI-D on the projector the picture turn grainie. WHY? However, when I disconnect the cable, the pix clears up on the...
It is probably mirroring the screens on your MacBook and the projector. If you want different resolutions and things on each screen, go to the Apple menu, System Preferences, Displays, Arrangement and uncheck the "Mirror Displays" checkbox.
Apr 22, 2009 | Sharp XR-30S Projector
Unable to Connect DV10
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Cannot access menu functions or display signal on projector
if you cannot access the menu, you have a main board issue that requires replacement.
Oct 07, 2007 | CTX Ez Pro 585 Multimedia Projector
Vertical control of viewing frame needs adjustment.
Did you try going into MENU --> PICTURE --> SIGNAL MODE, and then pressing > to go through all the signal modes? On mine, most of the signal modes split the screen weirdly as you described, but one of them (in my case XGA3, but I'm not using a Mac) looks right.
Nov 07, 2006 | Polaroid Polaview 211E Multimedia...
HP Ep7120 Multimedia Projector Logo
46 people viewed this question
Top HP Multimedia Projectors Experts
color wheel light...
Are you a HP Multimedia Projector Expert? Answer questions, earn points and help others
