Question about Logitech Cordless Mouse
We are four users, 3 wireless HP mice, and one plugged in to a USB. We are getting confused channels - i.e. not in control of our own mouse! Have changed channels on all wireless but the problem creeps back for some reason? Any help please
    President:
  • 2,923 Answers
Most wireless mice are running on 2.4Mhz frequency. Yes, they would really interfere with each other since they have the same freq. You mentioned that you already change the channels but you're getting the same problem.
What is the distance between each users? If you're near with each other, I would advise you to put divisions (i.e. glass) that would block the signal from traveling to another adapter of you wireless mice.
We cannot do anything but to put divisions.
Posted on Jul 26, 2009
How to connect a microsoft mouse to a microsoft 1447 dongle
The thw wireless mouse is paired from fabric wirh USB dongle for same mouse. You can't connect a wireless keyboard to it because they are no different frequency. Actually it's hightly improbable that you even could connect the USB dongle of a mouse with another different mouse. Explanations is logical: presumeyou are in a big office whate another 1 users have wireless keyboards or "mice". Now, imaginge the mess if the dongle of your keyboard should control the mouse of another 9 usrs.
Now, it's competely different with bloetooth keyboards and"mice"
USB Dongle for Microsoft Wireless Keyboard and Mouse 5000
Apr 08, 2015 | Microsoft Wireless Mobile Mouse 3500
I need to connect the mouse to my computer
You can get the correct driver from
http://support.hp.com/us-en/product/HP-Wireless-Optical-Mouse/4085925/model/4188112
After following instructions, you will need a RESTART.
However, be sure to install a fresh AA battery in the mouse.
Then after the restart, plug in the USB dongle. push the CONNECT button It is under the red light under the mouse) for several seconds.
You should be connected.
Please be aware that this mouse has had a lot of unfavorable comments from users. Complaints are:
1. Battery needs to be replaced after 1 day of use.
2. Mouse clicks on its own - very frustrating.
3. Mouse sucks.
This model is no longer supported by HP.
IMHO, get another mouse at Walmart. Save your stomach.
Apr 08, 2013 | HP WX412AA Mouse
New mouse does not work. I bought two of these HP FHA 3410. Niether one works. the mouse red leg (laser) lights up and when I push the botton on the bottom it flashes until i press one of its buttons. ...
Anytime you install new hardware, make sure you restart your machine. If it still doesn't work after a restart, you may need to search the Brand and model number on Google for drivers.
Sep 26, 2017 | HP Wireless Optical Mouse
Pointer drifts to the left left of the screen
Try to use a decent mouse pad. Optical mice are often confused by certain surfaces.
Mar 05, 2011 | Gyration Ultra Cordless Optical Mouse
I can't get my hp wireless mouse workn
The first thing to determine is whether or not you are getting a connection. Check to see if there is power on the device that is plugged into your computer. (The device which plugs in via USB). If you are not getting power to that, try a different USB port. If you are getting power to that device, follow Step 2:
The next thing to try is to look underneath the mouse. If you see a red light, it means the batteries are fine. If you don't see a red light replace the batteries. If that doesn't work, follow Step 3:
The next thing to check are the drivers on your computer. You will probably need a wired mouse to do this though. Unplug the wireless mouse, then plug in a wired one. Since I'm not sure on the model of your mouse, go to HP's website and click into the Drivers and Downloads section. Locate your mouse model number underneath the mouse or wireless transmitter, then search for the drivers. Once you have located the drivers, download them to your Desktop, but don't install them. Once they are downloaded, unplug the wired mouse from your computer, then plug in the wireless mouse and proceed to Step 4:
Before you install the drivers, go Start > Control Panel > Device Manager > Mice and Other Pointing Devices, then uninstall each mouse driver listed in here. You're doing this in case another mouse driver is conflicting with your current one. Reboot your computer. Once the computer is rebooted, go on to your Desktop and install that driver you downloaded from HP's website. Press the sync button on your wireless receiver (if there is a sync button), then try your mouse again.
Feb 18, 2011 | HP Wireless Optical Mouse
I have an older HP desktop and just added a new HP wirewless optical mobile mouse with usb. They seemed to work fine initially but then I needed to move the computer so everything was shut down and moved...
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | HP Wireless Optical Mouse
I HAVE A NEW NOTEBOOK AND WIRELESS MOUSE.
When you purchase the wireess mouse it should come with a USB device that plugs into a USB port and reads the mouse, all wireless mouses need a USB eye to read the mouse.
Good luck.
May 23, 2010 | HP P2360AA Keyboard/Mouse
My wireless mouse is not working
Hello sbregar here, your problem is not very hard try ALL usb connections, if that doesnt work go to HARDWARE under control panel and click new hardware, you go through a wizard and it should work thanks. :D
Feb 14, 2010 | Microsoft Wireless Notebook Optical Mouse...
GM323AA HP Optical 3 Button Wireless Mice I got from somebody is not coming on. Can someone give me step by step instruction on how to wt up mouse after putting batteries
I have the same mouse. Make sure batteries are good. Then plug in the usb receiver. On the receiver, press the green led light, then press the connect button on the underside of the mouse. they should connect.
Apr 03, 2009 | HP GM323AA Mouse
I have a mikomi wireless mouse and keyboard but i cant get them to work
hi frd
i think when you have purchase a wireless keyboard and mouse there is an user mannual in-side the box .
you must read it ok what ever...
(1) you plug the batterys which ever is required wheater it is AAA or AA in both key board and mouse.
(2) now plug the senser cabel in mother board in both jack of keyboard and mouse.
(3)now there was a channel selector back side of your keyboard and mouse.
(4) select in both channels same.
(5) now there was a reange search small push button with small nidle item till sencer detect it.
do it untill you can search item
your combo will work
thank you
Dec 11, 2008 | Computers & Internet
Logitech Cordless Mouse Logo
193 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
