SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
SOURCE: Need manual and battery info for Fossil S+ARCK PH-1002 watch
Of course, you can.
Open the watch and take the battery out. Memorize all the writings on battery and buy exactly the same one. You need to memorize wich way up the battery is originally fitted. If you will insert the new battery the other side up, you can damage your watch movement.
Rate me, please.
SOURCE: Fossil Watch Repair,crystal replacement Fossil TM7221
See SuisseWatchService.com for watch crystal replacement in the USA.
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
