Question about Kenmore Freezers
My stand up freezer
Is hot on all sides outside of freezer
    Problem Solver:
  • 6 Answers
If your freezer is working normally then this problem is normal condition as the condensor coils are behind the cabinet sides to radiate heat keep good ventelation around the cabinet
Posted on Jul 27, 2009
My frezer is getting hot on the sides-why?
Its normal. The manufacturers got smart and put the condenser in the outside freezer walls. A lot of home refrigerators also have the same hot walls. Hope this helps good luck.
Oct 06, 2014 | Kenmore Freezers
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Stand up magic cheef freezer unthawing and hot to touch
A freezer can't "unthaw". It can freeze or thaw. I assume your freezer is not cooling properly and is hot to the touch. First try defrosting the interior. Ice buildup will cause the problems you described. Also check the rear of the freezer and clean the cooling coils so they transfer heat to the outside air.
If neither of these things helps, have a professional check your Freon coolant level. You may have a leak.
Oct 15, 2013 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Bought an upright Frigidaire Freezer on Craigslist and the inside gets cold and works like a champ but the outside side panels get very hot- is this normal or is there a short?
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Aug 28, 2011 | Frigidaire 14 cu. ft. / 396 liter Upright...
My Kenmore side by side freezer is so hot on both sides I can hardly touch it.What can i do?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 24, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a stand up freezer and it its hot on the outside from the middle to the top on both sides. Is this normal?
Yes,
on many models this is where the condenser coils are to expell the heat...
heatman101
Sep 30, 2010 | Frigidaire Freezers
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
The outside of the freezer door is cold, and the surrounding floor is cold - even in the hallway outside the room the freezer is in. Can't find any obvious leaks around the door seal. The sides of the...
the # should be inside, the temp in side the freezer needs to be checked. does the thing ever shut off, if not it may need a cold control
Jun 28, 2009 | Freezers
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
226 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
