A noise is coming from the AC/heating vents, model Rheem.
Sounds like a belt is slipping and causing a squill. If this could be the issue, where is the belt and how do I replace it?
    Champion:
  • 363 Answers
Remove unit from casing if fan is belt driven you should see it, if fan is direct drive you sholud see that also.
Posted on Jul 26, 2009
Loud, low (bass) noise, not coming from the vent or the heating element
Most probably caused by one of the belts being frayed and about to break. You might want to replace the small drive belt (00096426) first as it does the most work of transferring the motor power to the shaft causing the drum to rotate. A worn belt can cause a low frequency hum and potentially slow down drum rotation as it slips on the hubs. Replacing the large drum belt requires a lot more work than the drive belt because you must remove both the front and side panels of the dryer; whereas, the drive belt is accessed by removing the right side panel.
Apr 25, 2015 | Bosch Axxis WTA 3510 Electric Dryer
When air or heat is on squilling sound comes on 98 buick century
If the squealing is coming from the engine you may need a belt. If it sounds like the dash it could be your blenddoor actuator having problems cycling or the blower motor
Oct 28, 2013 | 1998 Buick Century
Why does my car makes squilling noise when i crank up the car but stops
If the noise happens when the engine is first started, the serpentine belt may be slipping when the alternator is pulling hard.
Jul 15, 2013 | Cars & Trucks
I have a 99 Chrysler 300m when I turn the heat r ac smoke comes from the vents and from under the hood.. When I turn the heat/ac off it stops.. It has a smell like burning rubber
sound like AC COMPRESSOR clutch bearing going bad causing locking up putting drag on drive causing drive belt slip giving a burn rubber smell.
Jun 17, 2013 | Cars & Trucks
I have a 50 gal rheem water heater, its making a clicking noise i have discovered if i shut off the cold water supply it stops, when i turn it back on then the clicking starts again, my t&p has popped...
sediment build up is usually causes thumping and noises from tank. it needs flushed out. models, where the heat source is beneath the tank. The burner heats the water under the sediment, leading to a build of steam. The steam finally escapes as bubbles, which can cause the sounds.
have a good day !
Mar 14, 2011 | Rheem Water Heaters
When using hot water, the Rheem revs up like a motor cycle
I would check and see if the ventpipe that is coming off of the top of the motor is strapped to any duct work in the basement or touching and floor joyces. Even if the venting is touching the duct work a bit, it will amplify the vibration through out the home.
The only other issue it could be would be that the fan blades are bent and rubbing up against the inside of the motor causing the noise and extraem vibration
Jul 29, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Belt squeaks when AC turns on
Your belt is not tight enough. Are you using the power steering pump to adjust? (right way) or doing something else? Keep tension on the pump and tighten the pivot bolt first.
Apr 30, 2009 | 1995 Jeep Grand Cherokee
A squilling noise while driving, but not all the time,new brakes,
water pump bearings ,change it a bit quick if it is ,but get a hands on answer from a proper mechanic and not a spares counter assistant.and no iam not popping around for a quick look as 10 hrs on a plane doesnt help my back
Feb 18, 2009 | 2003 Saturn VUE
Dryer problems
sounds like the belt is slipping, check belt and tensioner, or possible vent clog. verify vent is open and unobstructed by turning on dryer with no heat selected then go outside and make sure there is lots of air coming out exhaust outlet.
Mar 28, 2008 | Dryers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
