Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video): https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance? If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
