Question about Home Security
Jensen RCS 70 backup camera in my motor is always out of focus
I have a Jensen RCS 70 backup camera in my motor home. It will not stay in focus. I have taken it off the back of the unit and cleaned it many times. Sometimes it is perfect, but most times now it is totally out of focus. Any thoughts or ideas where I can get parts or troubleshooting?
  • Paul Blessing May 11, 2010
    How is the picture if you take the unit off and test it?
jackboy
  • 2985 Answers
SOURCE: Pentax Ist DL auto focus not working anymore after using Quantaray AF LD 70-300MM Lens
It seems to be a connection issue between the Lens and the Camera body. Perhaps the mount is not true to the body Ask Pentax about this their Technical Support Team
Posted on Jul 07, 2007
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
  • 29 Answers
SOURCE: Plenio VXA-3000 Navigation Unit, powers on but screen stays off.
If you Need Plenio Tech Support
www.dvssale.com
Dan Kim 408-970-3388 office
DVS Sales Inc.
2398 Walsh Ave.
Santa Clara, CA. 95051
Email kimus@dvs.co.kr
posted 01.15.2009
jeffreydrescher@Bellsouth.net
Posted on Jan 15, 2009
randy320sgi
  • 121 Answers
SOURCE: nikon af-s 18-70 dx autofocus problem
ff1esta,
Moving a camera from cold to warm after it has been in the cold for a long time will cause condensation to form. It's a good idea if you can to allow the camera and lenses to gradually warm up. Like first in a garage or enclosed porch in the bag before binging them into a warm place. Since you have the moisture in it now you have to allow it to get out, the electrical components are at risk, the condensation or fog may have caused the lens not to be able to focus. remove the lens from the camera body and let both sit to air out. Since it's been over a week now if there is still some moisture you may want to get the camera into a shop to be cleaned and inspected to avoid corrosion.
randy320sgi
Posted on Jan 18, 2009
  • 117 Answers
SOURCE: auto focus fault with 70-300 sigma
It sounds like that the drive belt has worn you need a new one
Posted on Apr 26, 2009
Does the Nikon AF 70-300mm f4-5.6G Lens work with the Nikon D3100?
Yes, as long sa the lens can fit the bayonet. But it can't focus, because there are no AF motors in Nikon D3100 and AF 70-300mm f / 4-5.6 - G. And Nikon lens with AF is without AF motor. Lens marked with AF-S have focusing motor
Jul 23, 2013 | Nikon Cameras
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
I am thinking about getting a Nikon D3000 or D3100. Will my Sigma DL Macro Super 70-300 and Sigma 28-80 D work with these cameras.
If those lenses have a Nikon mount then they will fit on the D3000 and D3100. However, the D3000 and D3100 lack a focus motor. If the lens does not have the focus motor then you will not have the autofocus capability. Sigma calls their focus motor the HSM; if the lens does not specify HSM then they do not have the motor.
Dec 12, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
The Quantaray 70-300mm lens
Only if you get the version with the built-in autofocus motor. The D3000 lacks a mechanical AF coupling so AF lenses which need to be driven by a motor in the camera body will require manual focussing.
Either way, you're far better manually focussing the Quantaray/Tamron 70-300mm: the AF performance is very slow, very noisy and hunts around a lot to achieve focus.
Although the Quantaray and Tamron versions are identical lenses, if you have to buy this low-quality budget model then go for the Tamron: it's absolutely no better lens quality (and usually the same price), but the manufacturer's warranty from Tamron is much better than Ritz and is internationally valid. If you resell the lens then the Tamron will have some value (not much though) and the Quantaray will be near worthless as it's not so widely known, and has a poor reputation amongst those familiar with the brand.
"Cheap" isn't always the same as "good value"...
Mar 06, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
The manual focus seems not to be continuous, as approaching focus the step motor messes the focus to backfocus and vice versa.. !? I can turn the focus ring sometime focusing nearer and nearer but in some...
What kind of device are we talking about here? Actually, it doesn't matter, since this type of problem almost always requires servicing. Servicing or buying a new camera is always a process you have to make the call on. Get an estimate from a camera shop, and go from there.
Mar 04, 2010 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
D80 battery dies when using larger lens
If your 70-300 lens is using VR and your 18-135 lens is not then this is correct. VR uses a lot of battery juice so you should try to keep it off if you are not using it. Also, try toset auto-focus off also if you are concerned about battery life.
Dec 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikkor 70-300 f/4-5.6g lenses will ont auto focus on my D70
The focus motor gear assembly likely has a damaged gear. It will need parts replaced.
May 20, 2009 | Nikon 70-300/4-5.6 G AFD Nikkor Zoom Lens
Home Security Logo
466 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
