Question about Whirlpool Washing Machines
After each wash a ring of what looks like grease or mold forms around the top of the tub basin. It appears gooey or gummy and is a greenish brown.
  • 132 Answers
I THINK IT IS IMPORTANT Q :
IF THE PROB STILL THERE PLEASE FOLLOW THIS 1- SELECT A HEAVY PROGRAM LIKE COTTON WITH (90)oC
2- DO NOT BUT ANY CLOTHES
3-DO NOT BUT ANY SOAP
WAIT TO FINISH THIS PROGRAM COMPLETELY
IF YOUR PROBLEM DISAPPEAR PLEASE REPEAT
THIS PROGRAM EVERY MOUNTH...............THANKS
Posted on Jul 26, 2009
I hear water sound when I move the washer basin. Can this be drained without connecting power to the unit?
The sound is most likely the fluid trapped in the counter-balance ring mounted on the spin tub, DO NOT drain it out, you would be unhappy with the results. If you think water in the tub is causing odors and mold, you are wrong. Switch to POWDER and leave the door/lid open when you are not washing, the residue left by LIQUID soaps rots, stinks, and causes tons of premature failures of metal parts in washers all across the land. POWDER is HE also...
High Efficiency Powder Laundry Detergent Tide
May 13, 2016 | Washing Machines
I get a very strong smell from my maytag atlantis washer. it smells like the sewer. how do i remove that smell?
Confirm that the sewer trap is working. The sewer trap for a washer is the pipe connection where the washer drain hose connects.
It would not be likely that the trap is a problem. Sewer gas and mold can smell similar. Smell around the hose connection. Some older homes just simply had a drain to the outside
26162560-vtficdakbbyhbpkipaftpy0h-4-0.png Next this machine is a top loader and if it is being used several times a week the problem is likely around the tub on top. Mold will form in the tub under the basket if it is not run weekly. Normal wash cycle in a top loader should keep under the basket clear. If a week or so occurs between use then the problem can be under the basket at the bottom of the tub. Use bleach, vinegar, or baking soda in moderation to clear.
It is more likely that the problem is around the top of the top. this requires opening the top and swinging it back to get access. Make sure power is removed before attempting.
Cleaning a little bleach, soap and water.
26162560-vtficdakbbyhbpkipaftpy0h-4-9.jpg this helps?
Apr 13, 2016 | Maytag Washing Machines
What causes brown gooey ring around Dream Maker Eclipse spa and how do i prevent it
try non chlorine shock to shock it sounds like you used a chlorine product with it which will cause a gooey mess if it doesnt go away try to drain clean up everything including the filters or by new then try to use bromine that is more stabile in a spa
Aug 29, 2014 | Pool & Spa
Dishes have residual film after wash cycles. Grease has formed in the bottom of the tub and around the gasket and appears to be coming from the center of the machine where the motor-geardrive in located....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 08, 2011 | Maytag 24 in. MDB8600AW Jetclean II...
Smells grey sludge on clothes
its from all the old detergents not getting to the drain and lay in the outer wash tub,the smell is from mold starting to form in this gooey mess,you may need to remove the inner tub to get this goo out of the outer tub,then make sure the drain pump,hoses are also clean of this goop and there are no kinks,or blockages in the drain hoses or pump
Apr 29, 2010 | Bosch Washing Machines
Grease oil ring around tub and it smells like oil?
The only place there is oil in a washer is inside the transmission. If you have oil in the tub (and it didn't come from the clothes you put in) you have a bad transmission seal. It is generally cost prohivitive to replace the transmission. It's time to get a new washer. Look into the front load machines which use much less water and spin out twice as fast as top loaders. Some even have direct drive, which means no belt, transmission, or clutch.
Jul 19, 2009 | Washing Machines
BROWN GREASY RESIDUE LEFT IN BOTTOM AND TOP OF TUB
could be the transmission shaft rubber seal...need to call service tech for more help thee.
Apr 07, 2009 | Frigidaire GLWS1233A Top Load Washer
Oil ring left in tub and on agitator
If its oil your transmission is leaking oil. Time for a new washer.
Mar 21, 2009 | GE WJSR2070B Top Load Washer
Mouldy mildew smell
I had the same problem and I fixed it fairly easily in about 45 minutes:
The root-cause is the incredibly stupid design of the plastic ring that snaps over the plastic wash tub. It is filled with many nooks and crannies that rarely contact the wash water, thus getting scummed up and moldy. See a picture of the gross mess here: http://www.falselaborblog.com/2008/08/moldy-maytag.html
The fix involves opening the top (easy) and removing the ring (fairly easy) and can be done yourself if you are the least bit handy.
Unplug the unit.
***If you are mold-sensitive, wear gloves and breathing apparatus or have someone do this for you.***
Tape the lid shut so it doesn't flop open when you raise the lid.
Use a putty knife to push into the front seam about 1 1/2 inch from each corner. This unlocks the top and it will open just like the hood on a car. Carefully secure this in the open position and don't let it fall on your head or your hands.
You will see plastic fasteners holding the top ring around the outer plastic wash tub. These will unsnap (you may need a flat-head screwdriver for some of them).
Carefully lift this out and try not to puke when you look at the underside (see photo http://www.falselaborblog.com/2008/08/moldy-maytag.html). Take it to a laundry tub or bathtub and thoroughly clean it by scrubbing with hot water, detergent and bleach.
Before replacing the ring, use a thin brush to clean between the upper part of the wash tub and drum---the scum and mold will be in here also.
Replace the ring in the reverse of the above steps.
Prevention: There is none. You will have to do this every 4 to 6 months to prevent mold from infesting all of your clothing, etc.
I'm experimenting with limiting wash load size to "large" and never using "super", reserving the "super" setting for running periodic (hot water + Clorox) to see if it reaches the idiotic upper ring and keeps it clean. I am not hopeful that this will eliminate the need for these overhauls.
P.S.: The person that designed this washer should have all of his/her underwear and bed linens washed in an uncleaned Maytag Atlantis for life.
Aug 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
MOLD building on inside of dishwasher
are your dishes comming out dry at the end of the dry cycle and during dry cycle do you see steam comming out of the vent
Dec 31, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
