Krups Model 239 Blender runs fine but blade cavitates when 'blending' almost anything - soup, ice for marguritas, etc. Blade spins like crazy below a gob of unblended whatever above. Needs repeated coaxing with a spoon.
My K/Aid stand mixer not turning the beaters. I suspect that the nylon gear is stripped. How do I...
(More)
My K/Aid stand mixer not turning the beaters. I suspect that the nylon gear is stripped. How do I open the mixer? I have already removed all the applicable screws it appears that the beater platform needs to be removed. This is my problem how do I get this off? My mixer is a Custom 4ksm1model approx built in 2000. Help me?
The drive gear (coupler?), okay "thingie" that turns the blade assembly on my Krups 239...
(More)
The drive gear (coupler?), okay "thingie" that turns the blade assembly on my Krups 239 blender needs to be replaced. And ideas on how to remove it? I'd rather repair than replace. Thanks!
The motor works, but can't rotate the blade when the unit is empty (or full). I took it apart and it...
(More)
The motor works, but can't rotate the blade when the unit is empty (or full). I took it apart and it seems that tightening down the jar restricts the movement of the blade so that it cannot be rotated. I've tried not tightening the jar all the way down, and the machine works in an unsatisfying manner. The blade jumps about due to the extra vertical space and the jar feels wobbly when I move it. Is there a way to tighten the jar to it base without pinching the rotation base for the blade?
