Question about Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4)
My Linksys Wireless-B notebook adapter detects the wireless signal but will not connect
    President:
  • 2,923 Answers
Have you tried uninstalling/re-installing the driver? If not, try that and see if the device would connect to the access point or network.
If you're using the WZC (Wireless Zero Configuration) of the computer, you may want to stop and then start it again.
To stop/start the WZC:
1. Start > Run > type services.msc > hit Enter.
2. Locate and highlight the WZC by clicking on it.
3. Right-click it and there should be an option to stop it
4. Once it stop, right-click on it again and then select Start.
Hope this helps and have a great day!
Posted on Jul 26, 2009
How do you configure a linksys wireless-b WPC11 notebook adapter to connect to available wireless connections?
let me tell you its very easy.
Follow these steps to connect your Linksys adapter to available wireless connection:-
1.With this adapter you must have received a disk of driver for this adapter.
so install the drivers disk first.
2.Once the driver disk install then now you can search for available wireless network name.
To search wireless network in xp:-
start>>control panel>>network connection
now look for your wireless network connection.>>>right click on it>>>left click view available wireless network>>>here you can see the available wireless network name and now try to connect to your network name
Follow these steps for vista and window 7:-
Click on start>>Above start you will have search box>>in the search box type connect to
Apr 08, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Using Win 2000 on a laptop, Notebook adapter WPC54GV3 and a wireless-G Linksys router and up to date driver. Will not connect, inactive adapter.Do you have a solution ?
    It says the adapter is inactive. That means the adapter is not detected by the Linksys utility. Try to unplug the adapter and plug it back in. and restart the computer. now check if iot says active. If not then open the device manager and check if you can see the adapter there. If not then the adapter is not detected by the computer.
    Try to uninstall the adapter and reinstall it. Make sure that you have the CD of the adapter before you will uninstall it.
    Apr 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
    Wireless connection
    plug the computer into the router with a data cable. open browser and type in 192.168.0.1 or perhaps 192.168.1.1 -- when the router displays it will ask for a password. if you had one and can't remember it do a hard reset to return to factory settings. then log into it leaving the username blank with the default factory password. many times that password is admin -- download the owner's manual that will have the default password and instructions and explanations for the settings, including how to do a "hard, factory" reset for free at the manufacturer's website. try the help, support, or download sections. the drivers are there too.
    Apr 20, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
    Lost wireless signal
    Check the WLAN light on the Linksys Router if it's still on and make sure that the Wireless Adapter is ON on your HP computer and can detect other wireless networks, if WLAN is off try to do a power cycle and check again the lights... If lights are ok... connect your PC to the LAN port of the router and access the admin page, try changing channels and see if your wireless computer can detect it, if still not try to do a hard reset on the router
    Mar 02, 2010 | Computers & Internet
    Trouble installing wireless card
    If you're having installing the wireless card, try first to run the setup CD and follow the wizard in installing the wireless card and if it didn;t finish the installation , restart the computer and make sure the wireless card is connected to the computer and let the computer detect it and then a Found new Hardware wizard will come up just follow it , but if still fail better call Linksys tech support and let one of their tech walk you through with the process also to check if the wireless adapter is bad, they are open 24/7 this is the number 800-3267114....
    Hope that helps..........
    Sep 26, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
    Linksys Wireless not able to connect to internet
    Try it with Mozilla Firefox. If it works try some searches with IE, Windows ME and wireless as search terms.
    Jul 09, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
    My lap top connecting to my wireless system.
    Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
    Try configuring or verifying the wireless settings of the router first by following the steps on this link:
    http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4585&p_created=1165894972&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aXJlbGVzcyBzZWN1cml0eQ**&p_li=&p_topview=1
    After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
    http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_created=1160185039&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAyNSZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb25uZWN0aW5n&p_li=&p_topview=1
    If you cannot still connect wirelessly, let me know of the following:
    - model number of the router
    - operating system of the computer
    - wireless adapter installed on the computer (built in or external)
    - brand of wireless adapter installed
    - wireless settings of the router (SSID, wireless security)
    May 13, 2008 | Linksys Wireless-G WRT54G Router
    HP dv1000 laptop and internal wireless modem
    Although you have internal wireless, you are capable of attaching an external wireless device. For example, you could attached a D-Link WUA-1340 USB Wireless G adapter (http://www.dlink.com/products/?sec=0&pid=477), or, if you have a PCI port, you can use a Linksys WPC300N Wireless-N Notebook adapter (http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1144763513196&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1319686869B07). Either device with any brand will work just like your internal wireless. In fact, because you chose to use an external device, you may get a better wireless signal. Because internal wireless devices are inside the computer, it is more difficult to received a signal than with an external device.
    Apr 20, 2008 | HP Pavilion dv1000 Notebook
    Linksys WUSB300N adapter not detecting wireless links
    I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
    Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
    Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4) Logo
    173 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
