Question about Tappan TGF320 Gas Kitchen Range
Tappan gas kitchen oven will not heat
Our oven is not longer generating any heat. All 4 burners work fine, and the broil works fine as well - however the oven does not seem to be working.
  • Anonymous Apr 19, 2009
    all four burners are running fine as well as the ignitor is lighting up but its as if there is no gas running through to the oven itself
  • 248 Answers
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Posted on Nov 22, 2007
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Tappan Millennia range's baking component doesn't work.
Your ignitor has gone out or is no longer drawing enough current to open the gas valve. Replace the oven ignitor and it will fix your problem.
Nov 26, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
945 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
