Ricoh Aficio 1515MF All-In-One Laser Printer Logo
Posted on Jul 26, 2009
Paper is jamming
I have a Lanier LD015SPF unit and the papercontinues to jam on start up. What can this be?
Joe Fine
Level 1:
  • Contributor 628 Answers
  • Posted on Jul 27, 2009
Joe Fine
Contributor
Level 1:
Answers
628
Questions
Helped
149089
Points
66
When you say startup, do you mean when you turn the machine on or when you attempt to print?
For the first, check to see if there isn't any small piece of paper stuck anywhere in the paper path. for the second condition, clean off the feed roller with a piece of cloth dampened with alcohol.
  • Joe Fine Jul 27, 2009
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
How do you enlarge copies using a Lanier LD015spf
The option for enlarging copies on any printer are usually found under the "properties", or, "preference" tab/button. There should be sub-tab that says "scaling" that is defaulted at 100 percent. Increasing that number enlarges the copy.
Hope this helps. :)
I have a Lanier LD 232c. Every print job we try to send through is resulting in a paper jam. What should I look at?
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
1helpful
PAPER JAM IN TRANPORT
IF THE PAPER IS LAYING FLAT ON THE TRANSPORT WHEN THE JAM OCCURS, THE PROBLEM MAY BE A DIRTY TRANSPORT BELT SENSOR. A TECHNICIAN IS REQUIRED TO REPAIR THIS, AS IT INVOLVES DISASSEMBLY OF THE IMAGING UNIT.
The lanier printer in my office is saying -
there is a paper jam somewhere. sometimes two sensors are for the same area, open all doors remove paper trays look everywhere there is a green or blue handle
Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
