Question about Dryers
White knight 44aw not spinning and no heat - Dryers
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Jul 26, 2009
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Posted on May 10, 2010
Hi does anyone know how to replace door gasket on white knight 44aw dryer
Look under the lip near the mounting area. There should be a spring, just gently pull it around till it is 180 degree or more . it will fall off.
Jul 26, 2014 | White Knight Press 44AW White Tumble Dryer
White knight 44aw
There should be a tiny red reset button on the back. If you press this, it should resolve the problem
Dec 30, 2013 | Dryers
White knight 44AW
ref to my reply of 16.02.2014 @12.25 gmt
Dec 08, 2013 | Washing Machines
White knight
take the plug
does it make a buzzing sound or do you hear the motor turning
or if you spin the drum by hand it spins freely if it spins freely check the belt and jockey wheels
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
Oct 06, 2009 | Abbaka White Knight 44AW Electric Dryer
Dryers Logo
253 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
