Back to:
Tags:
Epson Stylus C43SX InkJet Printer
Black ink not printing (by 4 users)
posted by culun on Nov 22, 2007
black ink not printing
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by horne329, posted on Aug 27, 2008
when i filled up my printer with black ink it still won`t print black the color is fine
Comment by prakashrgp, posted on Mar 19, 2008
i own a epson c43sx printer ,. i ve changed the black cartridge as the old one has beco,me dry but i didnt put the colour cartrige and ,my printer not printing
Comment by Guest, posted on Dec 09, 2007
HP 5550 not printing from black ink cartridge. It acts like it's prionting, but it seems to be NOT making contact to the paper. Color cartridge is fine.
Clarification Request
by caterbusy, posted on Sep 30, 2008
I have the printer hooked up but it will not print the ink.
Best Solution
posted on Apr 19, 2008
FixYa! (100)
AntonioCirio
Rank:Guru Guru
Rating: 86%, 60 votes
You need to make the procedure of head cleaning several times after replace the cartridge, cause sometimes some air get inside the print head in the replace. Sometimes you have to repeat the cleaning procedure 10 times. Do a test after each procedure of cleaning, and watch when it was enough.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on black ink not printing:
I don't want to Accept this solution
Solution #2
posted on Apr 17, 2008
FixYa! (100)
dmltommy
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
To fix this problem I installed a new driver and switched the paper settings to high glossey paper...so far it works...black was the only problem...color printed fine.
Dina
Thank You!
Solution #3
posted on Aug 31, 2008
FixYa! (100)
alexar
Rating: 96%, 4 votes
This could be the time to get dirty and work with your printer. Try to clean the port where the ink tank is sitting on. Start using a couple cotton swaps with a drop of plain water and wash and dry the hole. Make sure, there is a flow of ink into the hole. Test your cartridge and see if ink emanate off it, before you install it. Sometimes the plastic on the cartridge is not perforated on the seat, and there is not a flow of ink.
Thank You!
Solution #4
posted on Dec 12, 2007
Helpful (85)
flyteach
Rating: 82%, 6 votes
I am having the same problem with HP 5550. New black and tri color cartridge (replaced because the black ink stopped printing). Grey will print, but not black. Put in a different (used and working fine) black cartridge and it still won't print.
Any ideas?
Thank You!
Solution #5
posted on Nov 13, 2008
Not Rated (0)
digable1
Rating: 0%, 0 votes
My epson C120 is working on the glossy photo paper setting as you said JJ, but text will not print on any other paper setting, does anyone know what could possibly cause this?
Comment by digable1, posted on Nov 13, 2008
I am having the same issue on my Epson C120(not printing text). Your tip did help JJ, but it wont print text on any other setting besides the glossy photo paper setting. Very aggravating for simple text docs. Does anyone have any idea what could be causing this?
Thank You!
Solution #6
posted on Sep 02, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
tae
Thank You!
Solution #7
posted on Feb 02, 2008
Not Rated (0)
JJ Sand
Rank:Master Master
Rating: 93%, 23 votes
This is what worked (so far) with my Dell AIO A940 printer that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Thank You!
Can you Help with these Printers problems?
Printers
HP officejet/HP officejet pro J4680 when installing...
how do you replace the black cartridge on an Epson Stylus...
whenever i try to print with my fonts all in dark blue, my...
Printer doesn't print. Green and Red lights are blinking...
Can i print if only the black ink is available and colored...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
