SOURCE: Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
SOURCE: clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
SOURCE: Quisinart DCC 1100 Series Coffeemaker
Hello sjones29,
This should be an easy fix. In one of the corners, under the top of the lid, you will find a water filter stick with a carbon filter that is likely clogged. Pull it out and remove the filter. Shine a light into the cavity of the unit and clean out the debris that may be in there. Replace the filter holder. (You can buy more filters on Amazon inexpensively). Filters are good for about 60 days. Then do a run through of water/vinegar solution. It should be 2 parts water and 1 part water. When done, run through a pot of fresh water to rinse. This should stop the light from blinking and make it so you can enjoy some great coffee.
Hope this helps and good luck! I appreciate positive feedback. :o) Thanks. NormanZ
SOURCE: Beeping only, and the coffeemaker won't brew at all
Check first that both filters (the water filter and the grounds filter) are in place correctly. Also check that the white tab in the grind cover moves freely when the lid is closed. (You can use a fork tine to test.) If that doesn't solve your beeping issue, contact http://www.cuisinart.com/support/us.html or 1-800-726-0190. I did and they are sending me a new unit at no charge.
SOURCE: This morning when my wife
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Testimonial: "Thank You Whispis2 ! I will surely clean the unit as described. Hopefully the light will turn off.Thanks again !! Dave"
