Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I uninstalled ATI by mistake, now my monitor will not work and it shows a message "out of range". I can't fix the problem because I can't use my monitor (I'm on another house computer). Help!
  • l0power Jul 26, 2009
    So I have to connect my monitor on my other computer to the one that I uninstalled ATI & then it will work...?
    Genius:
  • 1,043 Answers
Make sure you have the installation discs for your ATI card. While turning on your computer, repeatedly press the "F8" key. Eventually a menu should pop up giving you a number of choices. Choose Safe Mode. It will then reboot, and you will see a lot of different information. Don't worry that is normal. You may also get a Grey box that will ask if you really want to go to Safe Mode. Say yes. You will need to know what the Administrator password is for your computer. Once you have logged in, go to your Control Panel, and choose System. A window will open up with a number of tabs. Choose the hardware tab. Then choose Device Manager. A window will open. There will be a list of items with "+" beside each. Go to Display Adapters. Right click on each and every item there and Unistall them all. If after you choose each one you get a request for a reboot choose "No". Once they have all been unistalled, then let the computer reboot. It should boot normally now. Your computer will be working as a very basic display item. Once the bootup is finished, place your installation disc in your drive and install your drivers. This should solve the problem. If your computer will not show anything when you try your initial bootup to go to Safe Mode then you have a more serious problem. You will have to take your computer to one of your local repair shops and have them take a look at it.
Posted on Jul 26, 2009
  • bvanjoff Jul 27, 2009
    Actually you shouldn't have to hook up your other monitor. All of the monitors and graphic cards available are capable of working as plain vga equipment. If it is easier for you to do so you can hook up your other monitor to do the uninstall and reinstall. If, when you connect your original monitor back up you still have issues, as I stated you will have to have your computer looked at by your local shop.
  • 120 Answers
You need to use the other monitor because the display resolution is out of range already. You need to reset again the display properties.
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Dell laptop DVD issue
If you have Vista OS, it could be a problem after installing ATI's Catalyst Software Suite. If you recently installed it, try uninstalling it or rolling it back to an older version.
Mar 20, 2010 | Dell Studio 1737 Laptop
My monitor screen turned green..
Please check the VGA cable properly its working fine if any brokage then replace with goods one,if still same situation then your display setting has been changed from operating system .go to desktop /right click/properties/setting/advanced/select graphics card/graphics properties/color correction/and select all adnd apply it.
Nov 20, 2009 | ATI RADEON X1650 Graphic Card
Ati radeon grafix card 9550/x1050 monitor signal out of range
Try to check the screen resolution and the screen refresh rate. Try to set it first to 60hz for the screen refresh rate and try to set the screen resolution to 1024 x 768.
Aug 31, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
When I install ATI x600 drivers i get message "Cannot init direct show interface" when trying to run my TV Tuner. I have Creatix CTX918 tuner card. After uninstalling ATI driver it works fine.
hiya wasif_2000
this is driver bug in the catalyst drivers take a look at amd's site and try and download the lastest drivers for your gpu, u could also update directx from microsoft........should sort this out for you
hope u can get it working.......
Feb 23, 2009 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Flatscreen goes blank and displays the message
Out of range indicates that the refresh rate or resolution is set too high for the monitor to display. I would suggest re booting into safe mode by pressing F8 during boot, before windows begins to load. Select safe mode with networking if you can, and once in safe mode, uninstall the ati display driver from the control panel. Then go to ATI's site and download the latest driver for your card. Save that file to your desktop. Reboot normally, as Windows should load default vga drivers for your card. Once in Windows, install the latest driver you just downloaded. That should reset the resoultion to one that your monitor can display. Good luck:)
Jan 02, 2009 | ATI RADEON X1650 Graphic Card
New wide screen monitor incompatibility issues with older comp
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
Nov 25, 2008 | Computers & Internet
Radeon 9700 Pro Family
Remove your card. Clean the AGP slot & the video card. Reinstall the card. Still having trouble. Download the latest driver, below: Befor you install the latest driver package. Update windows. You will need .Netframwork ver. 2.0. Uninstall your current driver through Control Panel, ADD/Remove programs.
If the uninstall fails download and run ATI's uninstall utility: http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Driver package: http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Dec 25, 2007 | ATI RADEON 9700 PRO (128 MB) Graphic Card
Too many drivers installed, which ones to keep, which ones to uninstall?
1. uninstall or disable windows scripting
http://www.sophos.com/support/knowledgebase/article/10359.html
2. uninstall cataylst and install the oldest version possible from their site or from your box
3. reinstall the oldest or original via s3 pro savage driver
use a utility like advanced uninstaller pro if its hard to unsintall ur drivers
http://www.innovative-sol.com/uninstaller/
Dec 21, 2007 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
