Question about Google Talk
Connection error wount open keeps givin error message " can not authenicate server"
    President:
  • 2,185 Answers
Your antivirus' firewall may be causing this. Here is a link that could help you allow google talk from your firewall.
You can also do the following:
Add the Google Talk application (googletalk.exe) to the approved list.
Behind a proxy server that requires a proxy username and password? Follow these steps:
  1. Open Google Talk.
  2. Click Settings.
  3. Highlight Connection along the left side of the dialogue box.
  4. Select Use the following proxy.
  5. Tick the box next to Proxy requires Authentication.
  6. Enter the proxy username and password.
  7. Click OK.
Posted on Jul 27, 2009
How do reconncet to my server
Which error message? It probably a windows security setting issue. I have problems connecting to my DLNA server if I do so and a network share rather then as a media server for the same reason.
Sep 26, 2014 | Samsung Galaxy Tab Tablet PC
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
Feb 28, 2014 | Android 4.0 Tablet PC
What is wrong when you try to connect to your wifi and get an authenication error message
Authentication error means that the password you are entering to connect to the wifi is incorrect.
Hope that helps!
Oct 02, 2013 | Computers & Internet
Cannot load into Gmail
Check your wifi and see if it's well connected or not. I think this is the main problem. Good luck.
Jan 14, 2012 | PANDIGITAL Planet
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
Vpn connection
That error means it was unable to connect. Can't find vpn server or security was wrong. Are you running a firewall? If so, open port 1723 and try again or shut it down while testing.
Mar 12, 2009 | U.S. Robotics (9107) Router (USR9107A)
Error in installing yahoo!7 messenger 9.0
make sure you have the latest update on software by using windows update
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Oct 20, 2008 | Yahoo Messenger
Setting up SMTP mail service for Yahoo Small Biz Account
open outlook 2007 go to Tools / account settings
highlight your account and select change. this will take you to change email account. at the bottom if you have if you have Require logon using secure password authenication check uncheck it and then click on MORE SETTINGS / select outgoing server. make sure you have My outgoing server (SMTP) requires authentication is checked. and select use same setting as my incoming server. then click the advanced tab and check This server requires an encrypted connection (SSL) this should change the incoming port to 995, last change the outgoing port to 465 and click ok.
Oct 11, 2007 | Microsoft Office Xp Professional Full...
Google Talk Logo
250 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
