Question about Sub-Zero 690 Side by Side Refrigerator
Compressor area above refrigerator is getting very hot
Compressor area above refrigerator subzero 690 is getting very hot. Fan works and temperature in frig and freezer are fine. Fan runs almost non-stop.
    Sergeant:
  • 175 Answers
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Posted on Jul 27, 2009
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
I have a SubZero 690. Freezer is not working at all, Refrigerator is fine! Two different compressors or refrigertion units?
Hi, and no, you have only one compressor for this unit.It sounds as though your defrost timer is not working on the evaporator, stuck in the defrost cycle, and this is why its not freezing. It could be several different reasons the freezer stopped working. Check the fan in the freezer to see if its running.The defrost timer should be located behind the unit at the lower section. If this unit has a panel that is removable, you can take it off to find the timer and take a flat head screw driver to see if you can give it a 1/4 turn, as it may be stuck in defrost.While you are there, you will see the compressor, condenser fan motor, and condenser coil also. Clean this coil while your there and make sure the fan is up and running. If its not running, but the compressor is, the motor has failed. Take these steps and let me know the outcome.
Shastalaker7
Jun 07, 2011 | Sub-Zero 690 Side by Side Refrigerator
How can i buy a condenser coil fan
Call Subzero direct, if they cant sell you one they can direct you to a parts distributor in your area, 800-919-8324.
Jan 19, 2010 | Sub-Zero 690 Side by Side Refrigerator
Overheating condensors
Bad compressor. Anytime a compressor on anything gets to hot to touch that is a sign that the piston is applying to much pressure to work which in return causes the compressor to go bad if not caught right awya
Jun 03, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero 690 replaced lights but fan and lights dont work
The fan will only run when the compressor is running. Check it a couple of times to see if it actually is not going on. There is alos a light terminator located behind the fan cover. We will assume it is the light switch. For the light switch go to http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code. This will take you to a locator to find the authorized parts distributor for your area I believe the part number for the light switch is 3060140 have them check it using your model and serial number. Once you have the part remove the three phillips head screws that hold the grill in place, this is assuming you don't have the louvered grill. You access these inside the fresh food and freezer compartments. With the door open you look up in to the metal you will be able to see them. Once you get the grill off there is a grey power cord with a white quick connect disconjnect this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor. If this is too much the link above also is for authorized service in your area.
Dec 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
diane.white@subzero.com
Sep 18, 2008 | Sub-Zero 690 Side by Side Refrigerator
Subzero refrigerator (20 years old!) compressor is noisy and the frame of the refrigerator is very hot.
Was able to get an Authorized Subzero company here this morning with NO emergency service charge. Turns out the fan needs to be replaced and it also needed freon.
Aug 03, 2008 | Sub-Zero Refrigerators
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 690 flashing EC and service
If you replace the fan and clean the coils, and the refrigerator STILL does not cool, then contact SubZero or a service provider for an evaporator coil replacement.  Units manufacturer before mid-2003 had copper+aluminum coils that would corrode and allow all of the coolant to escape.  The (should be warranty) replacement is all aluminum.
Note the freezer does not have this issue due to the lack of liquid water.
Feb 20, 2008 | Sub-Zero 690 Side by Side Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 690 Side by Side Refrigerator Logo
609 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
