Irons Logo
Posted on Jul 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Norelco steam iron 1513 B, lights up, but does not get hot.
The indicator light that tells you that the iron is on, lights up, but the iron does not get hot. I have had absolutely no previous problems with it, one minute it worked and later the same day it did not!
Anonymous
Level 2:
Sergeant:
  • Expert 175 Answers
  • Posted on Jul 27, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
175
Questions
0
Helped
94307
Points
550
I think Thermostat is not functioning or Electric flow from Thermostat to Element is break. If you can open it, check it, otherwise contact some repairing engineer.
Regards;
Hassan
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Jul 26, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512593
Points
12435
It likely has a burned-out heating element. Probably time for a new iron.
2answers
How do I know when iron is at temperature to iron with steam
Flick a few drops of water on the hot iron plate and see if it sizzles. Otherwise, turn on the steam function button, and if the iron has water in it, when you tile the iron to iron, it wil.....STEAM.
Mar 26, 2019 • Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Team international steam iron
Make sure the valve between the base and iron is open.
Nov 23, 2013 • Irons
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Tefal protect concept steam button not working
hi! Long time listner, first time caller.
Iron not steaming AT ALL.
I have a tefal gv 7096
It turned on, all lights working and i can hear it heating up and when opening the calcium deposit i can see steam.
When i pressed the button - nothing. The iron it's self is hot (the plate) the lights on and but no steam.
The cord connecting the iron to the steam was also cold, so i could tell no steam was getting to the iron at all.
I wasn't sure if it was the button not working or something clogging the cord to the iron.
I did the vinegar thing. Let it sit for sometime (40 mins) and still nothing.
I did a weird thing of very carefully putting water on the plate while hot and it created steam from the plate. i think some backflowed and it started steaming, within seconds. might have happened with a bit more time anyway, but it def helped. All wokring fine now :)
Aug 10, 2012 • Irons
When my iron is on, you can't blast steam out. I drips water out instead.
Its the same thing i tell other postee, I assume you thought the iron is on because the lights are on, the problem is the supply to the lights are tap before parallel to the connection to the heaters. Most probably the connection to your heater is rusted(water seepage) or overheated(melted) thus there is no heat generated but the iron does indicate on.
2helpful
2answers
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
