Question about Datel Action Replay for Nintendo DS
How do you enter codes into the action replay??
First you have to turn the ar on. Put the game in and click on the star. (bottom left hand corner) Then click on add new code/cheat.then type in cheat name, then typen code at next screen.
Posted on Jul 28, 2009
I've entered the game and codes but when I try to start the game (With the cheat in it) it FREEZES what do I do to fix it
There are three problems/solutions:
1. You have entered an incorrect code. Check to make sure that the code is entered exactly like it is wherever you found it online. If it was already present on the action replay, try finding an alternate code online.
2. You have turned on too many codes. As a general rule, it's probably not advised to ever enter more than 10 codes at a time, or they may mess with the game and it will not work.
3. Your Action Replay doesn't work. Test to make sure that it loads with other games, or attempt to load your game with no code selected. If it doesn't work that way, then your action replay may be broken.
Mar 08, 2011 | Datel Action Replay for Nintendo DS
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
Aug 03, 2009 | Datel Action Replay for Nintendo DS
ACTION REPLAY POKEMON PLATINUM IT SAYS UKNOWN GAME
That's Easy. There's A master code you have to enter for the Game in your Action Replay. Go to Pokemon Platinum on The Games List of Your Action Replay. Then Click the Edit Button, But DO NOT change the Name. Just Click Next. Next It will Ask You to Enter New Game Id. Enter This Code: CPUE-3811DEF6 Then Click Next. Now you Should be Able to use your Action Replay for Pokemon Platinum. Enjoy.
Jul 24, 2009 | Datel Action Replay for Nintendo DS
My action replay wont start
my screen turns blue and red when i try to enter my game ID or a code can someone please help me
May 17, 2009 | Datel Action Replay for Nintendo DS
Can not press next with Action Replay DS v. 1.60
this may or may not work, but you can try re-callibrating your touch screen (orange botton in settings menu with crosshairs) or download new firmware/update action replay from your computer..... YOU HAVE BEEN WARNED: IF YOU DOWNLOAD FIRMWARE OR UPDATE YOUR UPDATE ACTION REPLAY, CODES YOU HAVE ENTERED YOURSELF MAY BE DELETED, BE CAREFUL AND MAKE SURE YOU WANT TO RISK IT. (i found out the hard way)
Apr 15, 2009 | Nintendo DS Lite Console
My action replay code manager is empty and I want to add pokemon
You need to restart your action replay.
to do this follow these steps.
1. hold A and B while turning on your DS.
2. at the Nintendo screen hold start and select.(still holding A and B.)
3. Let go when the screen saying, nintendo dose not''blah blah'' this product.
4. Turn off when you see the action replay title screen.
Once restarted try and add a code.
I had the same problem, but i did the above.
Apr 11, 2009 | Nintendo DS Lite
I keep getting the "White Screen Of Death" on my Action Replay
I bought a new one. I looked high and low for a solution, and could'nt find a way to fix it. I recomend buying a new action replay and letting the download FINISH, before you unplug it.
Mar 28, 2009 | Nintendo DS Lite
Heres your problem, I believe you just recently purchased this AR, the new version of action replay require a software update found on Datel's website, after downloading this software your Domain Suffix of your Optical Drive will automatically replace the program with the newer one. Open up your winsock processor and buffer the Native file of your AR back into your fluxus core before adding codes to your action replay, if this does not fix the problem, submit a complaint to the Datel Hacking Team located at PO box 45265 North Ridge, CA. This whole process should take anywhere from 10-12 weeks to fully resolve
Mar 23, 2009 | Datel Action Replay for Nintendo DS
Action Replay Problem
The problem is that the games or the ds action replay game slot is unfunctional. If it is the AR, just start up the action replay and eject it. Then put the game in, and start playing. To enter codes, leave the AR in and enter the codes. after you enter codes, the AR will save atomaticly.
Oct 20, 2008 | Nintendo DS Lite Console
Codes for action replay ds
Hi :-) heres a link that codes for millions of games for the action reply DS :-) hope you enjoy!
http://www.cheathappens.com/show_az_fav_main.asp?type=103
Jul 11, 2008 | Nintendo DS Console
Datel Action Replay for Nintendo DS Logo
169 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
