Question about Maytag Neptune MDG5500AW Gas Dryer
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
I have a Neptune Gas Dryer MDG300AW and the flame does not stay on. The cloths are not drying in the normal amount of time. I have made sure all the vents are clean, including the front one at the door and the exhaust vent. I took the front door off. I started the dryer by pushing the Door button. The electric starter came on and was red hot for about 15 sections before the flame started. The flame then stayed on for 1 minute and 40 seconds and then it went out. I kept the button pressed to keep drying running. The lighter came back on about 1 minute and 30 seconds after the flame went out the first time and then flame did light but only stayed on for about 15 seconds. Should the flame not stay on? What should I look at to find the part that is defective.
    Novelist:
  • 108 Answers
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Posted on Jul 26, 2009
Thank you very much. The gas valve coils fixed the problem.I purchased them from Repair Clinic, they were delivered, I installed the coils and it worked. Thank You
Posted on Jul 31, 2009
Why wont my Maytag Neptune gas dryer stay hot when I'm drying my cloths?
If you are sure that it is a gas powered dryer, the problem could be thermostat, flame sensor etc.
Oct 05, 2015 | Maytag Neptune MDG6700A Gas Dryer
Maytag ldg7500aaw gas dryer. I have replaced the coils, checked the flame sensor and the other sensor on the flame tube. It still ignites then goes off.
How long does the flame stay on? Burner parts, you may have a air flow issue, disconnect the vent from the back of the unit. run the unit. If the unit runs better, the issue is not in the dryer. If while disconnected the unit fail to still run, the problem is internal and will need to be taken apart to clean out the vent system in the door area.
Good Luck
Oct 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a neptune mdg5500aww dryer, goes on, glowing igniter... but does not turn on the gas... what is wrong
Their are 2 possible things wrong;
1) Does the igniter just stay on or does it glow and go off usually within 1 minute?..if the igniter just stays on and never goes off the FLAME SENSOR will be the problem
2) if the igniter does glow then go off but no flame..the coils that open the gas valve are bad
The part numbers are;
FALME SENSOR 338906
GAS VALVE COILS 279834
The parts could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Aug 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Mdg5500aww lp gas dryer heating problem it fires once but dosent burn long clothes dont dry help
When a gas dryer starts and the burner does not stay lit more than one minute the flame sensor is not detecting the flame to as a by design safety feature the burner is automatically shut off. It is not sensing flame so it is shut off.
This is the most likely suspect. http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
BEFORE you change this part make sure that the outside vent flapper and the ducting form the back of the dryer is free of lint. Disconnect the dryer vent and try it with nothing connected to the dryer. Also check around the lint filter area for lint especially in the bottom. If there is not a lint or ducting problem then by all means change the flame sensor.
Thanks for using FixYa!
Kelly
Mar 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Gas Dryer Problem
Be sure vent is clear, if vent is clear you may need a new set of solenoids for the valve.
Jan 15, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Gas burner only stays on for 5 seconds off 1 to 2 min.taks two hours dry clothes
No air flow. Blocked venting , Blower wheel broken or cloged. Check to see if the air is blowing out side at your vent. If your ingitor comes back on but no flame your gas coils are no good.
Nov 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
693 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
