Brother HL-1435 won't print, thinks it's out of paper
Our Brother HL-1435 had a paper jam, which we fixed, but now it constantly thinks it's out of paper and won't print. The green and red lights signalling ''paper'' are always flashing. We've cleaned it, reloaded the software program, nothing. It doesn't matter how many or how few sheet of paper we try in it. We tried unplugging and replugging the cords, too. None of the settings on the printer have been changed. What should we do? Is there a way to tell the sensor that there really is paper in our printer? Thanks!
Penny and Richard
    President:
  • 1,996 Answers
Please see the following support articles that concern paper feed and jam problems on your machine: here, here, here,
If the Paper Source is set to manual you will receive this error. (See use guide pg.1-10) (here)
REmove the paper tray completely, open the rear access door and make sure there are no bits of paper anywhere. Then reinsert and restart the printer.... If all else fails, you could try a factory reset as described here.
Posted on Jul 27, 2009
Brother HL-2132 not printing straight
Set the paper correctly in the cassette.
Feb 13, 2014 | Brother HL 1435 Laser Printer
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Hello, I just bought a brother hl-5370DW and am trying to use it to print out manuals for a class of mine using the duplex print but after a few papers print the paper going back in jams and it tells me i...
I just returned my HL-5370DW printer to Staples. I only had it for 3 days and found it running hot, warping card stock and envelopes, and jamming regular size paper constantly. It appears to be OK for very small print jobs but not very robust. I did like the duplex printing and the price. I do not believe there is a solution other than replacing this printer.
Xelzbear
Aug 06, 2010 | Brother Hl5370dw High Speed Wireless Mono...
I have a couple Brother Printers HL-1435 that are in alarm status and will not print. The Drum light will flash, and then the Drum, Ready, Alarm and Data lights all flash at the same time. How can...
This could mean one two things.
* The toner cartridge is nearly empty.
* You have a paper jam.
To replace toner cartridge:
Click this link to go to the Brother site where it will show proceddure with illustrations how to change the toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_011.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=7
To clear a paper jam:
Go to this link for procedure. It also has illustrations to assist you.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_005.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=113
I hope this helps.
Aug 04, 2010 | Brother HL 1435 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Jul 24, 2008 | Brother HL 5250DN Laser Printer
Printer
One of two things.
1. When the jam occured there may have been a small piece of paper torn off on a sensor.
2. And I think this is more likley. One of the sensor actuators has fallen off or is stuck causing the sensor to think there is still paper in the machine.
Take your time and examine the paper path carefully.
The actuators are black plastic pieces about an inch long hanging down into the paper path.
Jan 11, 2008 | Brother HL-2040 Laser Printer
798 people viewed this question
k24674
jasbo
jasbo
