Question about Frigidaire Gallery GLGF389GS Kitchen Range
What does error code f 1 mean on an electic range if i hit clear the beeping stops but comes back on in a few seconds
  • 91 Answers
Copied from another website:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part
Posted on Aug 26, 2009
F1 error code on Dacor RSD30S. Code comes on for no apparent reason, range not in use. Hitting cancel no longer resets range, I have to pull fuses to stop beeping.
The F1 error code means that a button on the touchpad is stuck and sometimes it could be resolved by clearing the code by pushing the cancel button, having done that and it no longer clears that F1 code the touchpad would need to be replaced to keeping it from beeping nonstop.
The part number for that touchpad is 82063B it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kitchen Ranges
When the stove is used for long time without a break, the alarm starts beeping and a sign "FO"appears under TrueTemp. On pressing the off switch a couple of times, the alarm stops and comes back...
Hello johal....
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
If you have to replace both, the parts alone will be $300. Therefore, consider a replacement not a repair if it comes to that. Joe
Thanks for choosing Fixya!
Jan 08, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Caloric gas range problem
Dec 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
F7 code flashes and beeps
F7 stuck keypad
Dec 10, 2007 | GE Profile JDP47 Electric Kitchen Range
Tappan gas range is beeping a code
This is what f 2 means for Tappan:
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor
Nov 15, 2007 | Tappan TGF657 Gas Kitchen Range
F1 Displayed
Carol, The F1 error code could be cause a failed ERC(EOC,Clock assembly)or a faulty touch-pad. To check the ERC and the touch pad, follow the steps below : -Disconnect renger's power cable. - Gain access to ECR's back. - Disconnect the ribbon cable between the ERC and the touch-pad - Reconnect renger's power cable and switch on. - If you will get the F1 and the beep,it means that the ERC is fault and should be replaced. - If you don't see the F1 code and don't have the beep, you should replce the touch-pad. Good luck !
Jun 13, 2006 | Kenmore 92329 Electric Kitchen Range
Frigidaire Gallery GLGF389GS Kitchen Range Logo
408 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
