Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Kitchen aid KSM 150 PSSM Flat beater removal???
I have my kitchen aid ( Betsy I call her! ) for about 5 months. I have waited and saved for a very long time to be able to afford one!! Now, I just made mashed potatos (most use) and the flat beater won't push up and turn for removal! I checked the website..... not helpful unless you have a major appliance problem. I shot off an email to support and I plan on calling tomorrow morning. I am very dismayed. Anyone have any ideas as to the issue here?
  • ammonfamily Jul 28, 2009
    Thank you thats just what I did and my new one is being Fed Exed.
    Problem Solver:
  • 18 Answers
Contact kitchenaid in greenville ohio that is where the factory is they should be able to help
Posted on Jul 28, 2009
I need a flat beater for a K4-B kitchenaid mixer, probably 40 plus years old but works great. do you have one?
Have you contacted Kitchen Aid service department and asked if another flat beater from a current model will fit?
Jan 25, 2016 | KitchenAid Food Mixers
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
Aug 27, 2012 | KitchenAid Food Mixers
Canot take the beater out of the mixer.when I have mix my my cake I cant get the beater out to clean the beater.
counter top appliance number for kitchen aid is 1-800-541-6390 M-F 8-8 EDT, and Sat 12 -5 p.m.
Oct 21, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
Please help me get the beater blade out of my mixer!!
your going to have to do some quik jerks, I have seen this plenty of times, has beater bars ever been removed or how long have they been sitting
Nov 25, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
The beater won't come off of the mixer. Kay
pour a little cooking oil in beater socket and wiggle it_Ned_
Nov 02, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Feb 05, 2009 | KitchenAid K45SS Classic Stand Mixer
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
181 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
