Back to:
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Need Diode part numbers for Philips Y-Main board (by 2 users)
posted by Old Drummer on Nov 22, 2007
I have a Phillips 42PF320A/37 Plasma TV (Chassis # BP2.3U) with red flicker, (see http://www.fixya.com/support/t246142-red_noise_or_flicker_bottom_half_plasma) and thanks to Premtech I've located two defected SMD diodes on the Y-Main Board. The reference designations are D5001 & D0018 and I'm unable to determine either Philips or commercial part numbers for these. They both have the marking F4 over 5J. The board is a Samsung PCB Code LJ41-02759A and Service Manual states that for Service it is a "Black Box" suggesting it's not repairable at component level and calls for board swap. I'd like to try and repair it.
Also, if someone the board schematic it would help me fault isolate associated circuity.
Comment by Old Drummer, posted on Nov 26, 2007
Did some more DVM testing and determined that U5014 is also bad but with no replacement part numbers, I chose to remove the board. I have emailed PTS on Friday for repair quote or replacement board cost and also how to register. Their site keeps redirecting me to a page requiring a username. They have not responded yet.
I removed the Y-main board with the upper and lower buffer boards intact so as to not damage the boards. I am not sure if there are locking devices on the large black connectors CN5404 & 5504. Also is there a special tool for un-connecting CN5406 & 5506? (See photo)
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dmt47, posted on Oct 07, 2008
I have a Philips 42PF7320A/37 with seven blinking lights. Repair cost through an authorized service rep is too high: $600+. After reading on line it appears my problems are in the Y Main or Y Buffer. Do you think PTS may be able to help with my challenge?
Thanks
Best Solution
posted on Nov 22, 2007
FixYa! (100)
premtech
Rank:Guru Guru
Rating: 89%, 928 votes
Old Drummer, that is indeed a BB board... It's propritary... It's that way because Samsung doesn't want Philips stealing it's ideas to make their Tvs..
The only authorized center for those is PTS Electronics and I believe Tri State Module is about to get authorization soon... Other than that it is not replaceable at component level and those part markings will do you no good - they're not in any list that you'll ever find...
Comment by premtech, posted on Nov 22, 2007
PS... Good job static testing to find two smts... Is that all you found wrong? No regulator failure?
Comment by premtech, posted on Nov 26, 2007
Old Drummer,
No special tool to unbutton the buffers from the board, but that's fine just the way it is... Just call PTS 800-844-7871 and you should be able to speak with someone regarding the rebuild.
Simply send it in - in a well padded box - and it takes about 10-15 days normally turn-around. Might be a bit longer with the holidays upon us..
Bill
Rating Locked! (?) Old Drummer has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Need Diode part numbers for Philips Y-Main board:
I don't want to Accept this solution
Solution #2
posted on Feb 22, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is a follow up for others with the same problem. Thanks to Premtech's advice, I sent all 3 boards to PTS and they resolved problem by determining that the lower buffer board was defective and they repaired it. I now have a great HDTV. Thanks again Premtech.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Aug 21, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
YO tengo un samsung que presenta la imagen con brisa a la mitad, despues nitida y mas abajo con brisa como si fuera un problema de horizontal yo quite la y main y la voy a cambiar para mejorar ya que presenta tambien recalentamiento por la parte de arriba y abajo
Thank You!
Solution #4
posted on Feb 16, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I have a phillips plasma that is also having this same problem. I suspect it is this same PCB that is bad. Did you end up getting yours fixed?
Thank You!
Can you Help with these Flat Panel Televisions problems?
Polaroid FLM-323B Television
i have a problem with the sound too. nothing is coming out...
Question Hi we have a Thompson Wysius 42'' plasma tv and...
Sony MFM-HT75W 17 in. HDTV-Ready LCD...
We own Sony MFM-HT75W LCD TV which was thought to be...
Sharp Aquos LC-37G4U 37 in. HDTV-Ready LCD...
I have a Sharp Aquos TV but don't have the manual. It has...
We have a magnavox hd tv almost 1 year old connected to...
Loading problems.
Repair Service
Find Flat Panel TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
