Question about Yamaha RX-V663 Receiver
Continually shuts off
Samething.. Have no idea what to do
    President:
  • Yamaha Master
  • 1,114 Answers
Disconnect all speakers from the unit then turn on, if it still cuts off, it needs serviced. If it stays on, post a comment and I can walk you thru troubleshoothing. Hope this helps
Posted on Jul 27, 2009
My HP c4580 states that the cartridge is missing or undetected.So I reinstalled the cartridges and it says the samething,WHAT DO I DO?
It's a new cartridge you fitted?
If not, it's probably because it genuinely is empty.
If new:
Remove all the cartridges. Switch off the printer.
Switch the printer off and reinstall the cartridges.
Switch the printer on.
Switch the printer off.
If you continue to receive the same error message it's because the cartridge isn't fitted/seated correctly, or that cartridge has a problem.
Feb 24, 2016 | HP Photosmart C4580 All-in-One InkJet...
2003 nissan murano won't restart after running hot. The engine has to cool completely. Also won't start if extremely cold. Engine cranks but won't start. Battery and black ground cable are new.
I had a car did samething had a bad fuel shut off relay design to shut off fuel if car rolls over, have a ford still looking to resolve same problem. good luck
Oct 04, 2013 | 2003 Nissan Murano
Phone shuts off, turn back on battery shows low. wifes phone does samething. not a battery issue.
Yes it is a battery issue. Take out the battery and spin it on a shiny flat surface. If it spins, even the slightest, that indicates a swollen battery and it won't hold a charge or charge completely.
Jul 28, 2017 | Samsung Conquer SPH-D600 Sprint 4G...
Compaq Presario M2000 Start up is fine screen gets grainy and gets darker and locks up.Ok from times of 3 min. to up to 3 hr.then need to do hard shut down. Restart fine and then samething. Also with batt....
Thank you for using FixYa
That sounds like a possible Virus or your video portion of the laptop is bad. I would recommend you take it to a qualified service center, it is unlikely that you will be able to do anything with it, if you cannot get it to come on and display.
I hope this was useful and please comment if this was helpful to you.
Apr 25, 2011 | Computers & Internet
1989 Ford Bronco. When I hooked up my battery I can hear the high pressure fuel pump running even though the key is turned off. I can start the truck up and it will run for a while. I took it for a spin...
if the key is off and the fuel pump still running then the fuel shut off switch and or the fuel pump is bad and needs replaced. More than likely the fuel pump might need to be replaced. (my 86 5.0 did the samething)
Aug 12, 2010 | 1989 Ford Bronco
TV shuts off after on for 5 minutes, Red temp light blinks once every 5 seconds, The power light stays red and blinks and you can hear fan running until unit is unpluged. You can turn it back on but the...
bad connection inside in motherboard. If you are familiar with soldering check for bad connection inside and re-solder that connection . if not find a technician who can help you!!!
Sep 12, 2009 | Televison & Video
Amp goes into protect when turned up.
that amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Aug 28, 2009 | Sony XM-2002GTR Car Audio Amplifier
Electrical
what is the diagram of the fuse box
Dec 17, 2008 | 1999 Lincoln Continental
Won't stay running
Replace start switch and if you find it still doing the samething then have a service tech.replace the motor.
May 28, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Yamaha RX-V663 Receiver Logo
297 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
