Question about TruTech T650-DR DVD Recorder
I accidentaly set my dvd recorder to PAL and now the screen is black and I can't get the menu to come up so I can change it back. Is there some way to reset the device back to factory default?
  • 8 more comments
  • hector depina Jul 26, 2009
    didn't work. dvd stops playing when i press stop button, but still have no picture. pressed the system menu button, it says sys on the display screen on the actual unit but still no picture.
    brand is Trutech t-650dr
    currently connected with s-video cables. I do not have HDMI cables, but I do have RCA and Coaxial cables so I can hook it up either way.
    also have component cables
    already tried that, didn't work, but i will try again.
    Nope, still doesn't work.
    that's right, doesn't matter wich way I hook it up there is just a black screen. when I first changed the setting to PAL the screen went to black and white and started rolling but then just went black and thus my current situation
    still there?
    I have a brand new magnavox 32mf339b/f7 hd tv, it is set to component input and the dvd recorder is connected via the component cables to the component input on the tv.
    I do not know if the tv is PAL compatible or if it is how to set it to PAL.
  • 10,594 Answers
I think Progressive mode is selected/ activated and causing no video out to your TV, that needs to be deactivated.
Press STOP key on DVD Recorder for 6 seconds to turn progressive Off.
Let me know exact model and brand if problem still unsolved.
Thanks.
Posted on Jul 26, 2009
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Jul 26, 2009
    OK, let me know connection setup of dvd recorder with TV.
    Is it hooked with TV through HDMI or Composite video cable (yellow-red-white RCA pins)?
    OK, please find Component Video Out pins at back of dvd recorder, its colors would be RED-GREEN-BLUE and if your TV has same Component Input, just hook 3 wires for video and make sure RED to RED, Green to green and Blue to Blue. Switch TV to that component input to get dvd recorder picture in TV. Once picture is there, change dvd menu accordingly to switch back to previous connection setup.
    If you wish, let it remain on component video connection setup. Need 2 more RCA wires plug in for sound in TV.
    If PAL is selected in dvd recorder, still you can have picture in TV though it would be Black and White and scrolling. Black screen shows dvd recorder switched to component video (progressive mode) so no video out in composite video (yellow pin) and S-Video out.
    Yes, I'm here.
    OK, that means dvd player is still set on PAL and TV might lost / changed Input.
    Please check what Input of TV is used with dvd recorder and set TV on that input to get back PAL rolling picture.
    I think you also need multi-system TV that has PAL color system inbuilt to correct dvd recorder color system.
    Shahid Electronics Jul 27, 2009
    I think 32mf339b/f7 is only NTSCand has no Pal system.
It's showing the video in a split, black and white screen
could be a pal/ntsc region code problem, either the menu setting is pal and your playing a ntsc region coded dvd or the menu is correctly set at ntsc and the dvd is pal that you are trying to play
Dave
Dec 27, 2010 | Initial IDM-1210 Portable DVD Player
We have a Philips DVD Recorder a Freeserve Digital box and a TV. Since adding the DVD Recorder we cannot tune in Freeserve at all and DVD's play only in black and white. Help Please. ...
Hi Jack,
And if you remove the DVD Recorder, everything is back to normal?
Initially, I would suspect that your DVD is set to PAL system and not to NTSC (or could be the other way around). Could you pls post back with the exact model number of the Philips DVD Recorder?
Additionally, could you pls detail how the Freeserve Digital box is connected to the Philips DVD Recorder and then to the TV? Pls indicate if you are using Video IN/OUT, S-Video, HDMI, SCART, RF IN/OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
My DVD player/recorder, records color but plays black and white
Check in the menu to see if there is a function where you can change from ntsc or pal,you need to be on pal
Oct 29, 2009 | Televison & Video
Bought a direct dvd recorder Sony DRV-MC10 on Amazon.USA,namely imported from USA to Greece. I can only record fotos on the DVD. When trying to record on dvd through all input connections I get an error...
Yes, the problem with electronics is the US uses NTSC and most other countries use PAL, it changes how the tape head alignes with the tape. You have to insure the device you have is both (most devices are) so try and get into the menu settings and see if you have a PAL/NTSC video selector option. If so change it to PAL.
Oct 27, 2009 | Cameras
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Overseas dvd playing in black & white instead of colour
Hi
Your DVD is in Pal mode change the system settings Thanks@!
Nov 27, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Set up menu
My friend check in the remote control if they got the progresive scan button or tv sistem and try to deactivate.
Aug 20, 2008 | Protron PD-DVR100 DVD Recorder
LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Nov 22, 2007 | LG DK 9411P DVD Player
TruTech T650-DR DVD Recorder Logo
54 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
