Question about Grilling
Need to order parts for Members Mark Gas Fired Ignition Charcoal Grill Model:CG2001201-MM-00
  • 35 Answers
Just Google it and you'll find a number of places, such as:
https://www.appliancefactoryparts.com/gasgrillparts/brands/members-mark/
Posted on Jul 22, 2017
CMV9
  • 594 Answers
SOURCE: One touch 22" charcoal grill
here is the link to the weber one touch 22 1/2 grill
http://www.weber.com/support/manuals/?id=1
please do not forget to rate and comment about your experience on Fixya today.
Posted on Aug 17, 2008
  • 8 Answers
SOURCE: charcoal grill to propane
Shouldnt be a problem, the sell replacement kits for propane grills at most home improvement stores. Just buy the replacement kit and install it into your grill.
Posted on Feb 16, 2009
bulldogchief
  • 388 Answers
SOURCE: Charcoal in a gas grill...Wassup with that?
Well are they lava rocks or charcoal? The Master Flame series is supposed to have lava rocks. If what you see is charcoal, remove it and replace with the lava rocks. You can order the rocks from Char-Broil's website.
Posted on Sep 07, 2009
  • 54 Answers
SOURCE: Patio Classic Grill Parts
http://www.grillstuff.com/gas-grill-cooking-grids/?cat=49 Should be able to get one that fits with the measurements.
Posted on May 25, 2010
kjhbef
SOURCE: meco swinger bbq spare parts
Hi, parts for your item can be found at amazon. Click here Amazon com meco swinger charcoal grill and take a look. I hope this was helpful. Cheers
Posted on Dec 15, 2014
My new grill has three parts that are damaged right out of the box. How do I get them replaced?
Take it back to whomever you bought it from and ask for an exchange.
Apr 05, 2017 | Grilling
Bought a members mark hybrid grill model number gr2071001-mm. Attempted to put it together but when I opened the box I discovered that it did not come with an instruction manual. Where can I find one at...
check with the store where you got it, if they dont have it go to the manufacturer of the grill. they will need the information from it and should be able to give you one.
Dec 24, 2014 | Grilling
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
Don't know how to use my propane, charcoal and fire box grill
Did it come with any sort of manual? That is probably the best way to start. If you haven't done it yet, hook up the propane tank to the hoses on the grill. I would say that the rack under the grill is for storing the propane tank and bags of charcoal or wood. Of course, the knobs are for turning the gas on and off. In between the left most knob and the one to it's right, there is an ignition switch type button, you press it when you have the gas turned on and with a lighter, you ignite the propane. Do NOT turn the gas all the way up before it is lit though, that is a sure way to burn some hair off or actually do some serious harm to yourself. In the charcoal section, you put maybe three inches of charcoal in the bottom of the cylinder. Use some paper or dry pine straw as extra fuel to get the charcoal started. Put a bit of lighter fluid on the charcoal then drop a match on it. I'm not too familiar with fire boxes, but from what I see, you need to use wood in the bottom of it. I can't see under the fire box, but you probably can dump the ashes out after you're finished with it. Start a fire with the wood and cook your food. If I may add a suggestion about cooking with wood, don't use nasty old rotten wood to do it. Cut some good smelling wood and let it sit for a while before you burn it. It will imbue the food with a good smell and taste. Other than that, it is up to you to learn to use your new grill. Good Luck.
Mar 30, 2013 | Grilling
I was looking for the manual for the Char Broil "charcoal" grill, not the gas grill...
Unfortunately, the model number you listed is for a gas grill. There is not Char-Broil Charcoal Grill, that comes even close to that model number. If may have been discontinued. In any event, contact Char-Broil Customer Service 866-239-6777. If there's a manual available, the will email it to you.
Sorry for the confusion, but I based everything on the Model Number you provided.
May 11, 2011 | Char-Broil 461630208 Charcoal Grill
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
Meco swinger bbq spare parts
Jun 26, 2010 | Meco 4400 Swinger II
Using ceramic briquettes with lp gas grill
Many people enjoy using Lp/gas grills for their ease of use and efficiency. Frustrations caused by flare ups and hot spots encourage the use of a wide variety of briquettes and other products. Ceramic briquettes are most commonly used because they provide an even heating surface and last for several uses.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. "SOOC" is Copyrighted by Flickr user: Robert S. Donovan (Robert S. Donovan) under the Creative Commons Attribution license. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.co.uk/images/a05/8n/jr/should-use-briquettes-gas-grill-1.1-800X800.jpg'); }); Types
  2. Gas grills most often use ceramic briquettes, lava rocks or, more recently, ceramic tiles in order to distribute heat. Ceramic briquettes come in the traditional shape, lava rocks are similar to those used in landscaping, and tiles only differ from briquettes by shape. Traditional charcoal briquettes can be used, though they maintain several disadvantages. Use
  3. Place briquettes, tiles, or lava rocks in a solid layer on a screen between the heating element and the grill surface, making sure to leave space for air to circulate. Light the grill and check to make sure that all areas of the heating element are covered, filling any empty spaces. Advantages
  4. Ceramic briquettes, tiles and lava rocks all serve the same purpose. The advantage comes from their ability to reduce flare-ups and hot spots. They can also be used several times, minimizing set-up and making cleaning easier. Traditional charcoal briquettes are cheap and easy to find. They also provide the smoky flavor associated with traditional charcoal barbecuing. Disadvantages
  5. Ceramic briquettes, tiles, and lava rocks are not as easy to find as traditional charcoal briquettes and are more expensive. Traditional charcoal briquettes do not repel run-off from food, but rather retain it, causing hot spots and flare ups. Charcoal briquettes also need to be replaced after each use and are harder to clean up. Warnings
  6. Any additional product placed inside a lp/gas grill should not come in contact with the heating element. Doing so can cause increased stress to the grill, as well as clog vital gas ports. Always maintain a clean grill. A buildup of old briquettes can cause inadequate performance.
May 01, 2010 | Ducane 30400040 Stainless Steel Grill
Sep 06, 2009 | Char-Broil CharBroil Master Flame Gas...
Grilling Logo
391 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
