Question about Kenmore Dryers
Kenmore 90 Series Electric Dryer - No Heat
Kenmore model 110.68972890 - 90 series electric dryer
Problem: no heat
We had a problem with PTS & not heating: We went by Dryer Tech Sheet and replaced Even Heat control Board and Motor Relay; PTS problem is resolved.
We again went by Tech Sheet and replaced Thermistor. However, for heater relay we're still getting 0V DC between P3-1 & P3-2 and 240V AC between COM & NO.
There is no voltage (reads 0V AC) between L1 & L2 going into Heating Element. We do have 240V AC between L1 & L2 that comes into the dryer.
Any answers to resolve this would be highly appreciated.
  • 5 Answers
SOURCE: heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Posted on Mar 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
Posted on May 10, 2009
protek480
  • 1723 Answers
SOURCE: My Kenmore 90 series dryer runs but will not heat
watch the video:
Posted on Jul 11, 2009
  • 35 Answers
SOURCE: Kenmore series 90 electric dryer does not heat and
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
Posted on Feb 27, 2010
  • 2694 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
KENMORE 90 SERIES GAS DRYER NO HEAT IS THERE A PILOT
heatman101
Jun 27, 2011 | Kenmore Dryers
My Kenmore Series 90 heavy duty gas dryer does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 19, 2011 | Kenmore Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Electric kenmore 90 series working but no heat?
May 10, 2009 | Dryers
Kenmore series 90 no heat
Check the glow ignitor on the right side of the dryer if you are looking at the front on the bottom side and make sure that it is not cracked
Feb 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
576 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
